Classifieds » Miscellaneous » HKS pod, Microtech ecu, p/s pump...
STR8 2.8
HKS pod, Microtech ecu, p/s pump... Fri, 10 September 2004 06:17 Go to next message
HKS Pod Filter, brand new filter (never driven with), cage is a bit rusty.
$35
http://members.optusnet.com.au/christopha/pod.jpg
http://members.optusnet.com.au/christopha/pod2.jpg
Silicon Reducer 80mm-63mm, fits hks pod (also have a wonderful high performance metal pipe to fit the other side)
$25
http://members.optusnet.com.au/christopha/reducer. jpg
Microtech D4s Fuel Computer, with loom for 5mge, diagrams
$100SOLD
http://members.optusnet.com.au/christopha/ecu.jpg
One Falken Ziex 235/45/17
pretty worn on edge, good for spare/burnout, (its just dirty in the pics)
$5
http://members.optusnet.com.au/christopha/tyre1.jp g
http://members.optusnet.com.au/christopha/tyre2.jp g
http://members.optusnet.com.au/christopha/tyre3.jp g
Also, if there are any desperate MA61 owners looking for special parts, i may have what you are looking for.
Chris
[Updated on: Fri, 17 September 2004 08:39]
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Fri, 10 September 2004 08:57 Go to previous messageGo to next message
bump
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Fri, 10 September 2004 11:11 Go to previous messageGo to next message
bump
BlackSupra
Re: HKS pod, Microtech ecu, p/s pump... Fri, 10 September 2004 22:56 Go to previous messageGo to next message
drivers door locking actuator
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Sat, 11 September 2004 03:30 Go to previous messageGo to next message
you'll need to speak to mike about that, he got the doors.
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Sat, 11 September 2004 14:23 Go to previous messageGo to next message
bump
ed_ma61
Lost in the K hole
Re: HKS pod, Microtech ecu, p/s pump... Sat, 11 September 2004 14:31 Go to previous messageGo to next message
external trim along the bottom of the back passenger windows - goes from b pillar to the funky triangular metal cover at the back corner of the window. need both sides.
also after driver side indicator lens (front)
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Sun, 12 September 2004 01:37 Go to previous messageGo to next message
no can do on the trim, but i do have indicator lenses.
Darryl
Sunshine Coast Queensland
Re: HKS pod, Microtech ecu, p/s pump... Sun, 12 September 2004 07:51 Go to previous messageGo to next message
$100
Is it mapped for a 5MGE?
Does it have an internal MAP sensor or does it require the standard air flow meter?
Allways looking.....what have you got? Cool
[Updated on: Sun, 12 September 2004 07:52]
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Sun, 12 September 2004 10:25 Go to previous messageGo to next message
it is not "mapped", it is an analogue computer.
it has an internal map sensor.
as for the ma61 parts i have lots of interior, a few exterior parts and some more.
its easier just to tell me what you want and i can tell you if i have it.
Re: HKS pod, Microtech ecu, p/s pump... Sun, 12 September 2004 10:28 Go to previous messageGo to next message
any black interior parts?
seats, intact aircon vents (the little ones at the side that dont move, that always break)
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Sun, 12 September 2004 10:33 Go to previous messageGo to next message
haha i have a million and one parts and nothing anybody needs.
all my interior parts are blue.
Re: HKS pod, Microtech ecu, p/s pump... Sun, 12 September 2004 10:48 Go to previous messageGo to next message
I only want a few parts, and it take forever to find the bloody things!
Re: HKS pod, Microtech ecu, p/s pump... Sun, 12 September 2004 10:49 Go to previous messageGo to next message
ps - if your blue crappy vents mentioned above are in good condition, I'll buy & dye them
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Sun, 12 September 2004 10:50 Go to previous messageGo to next message
once again... Laughing
the dash went to the tip with the bare shell
Darryl
Re: HKS pod, Microtech ecu, p/s pump... Sun, 12 September 2004 12:07 Go to previous messageGo to next message
STR8 2.8 wrote on Sun, 12 September 2004 20:25
Then consider it sold!
Very Happy
PM me your bank details and we'll go from there.
Postcode here is QLD 4560.......so you can add postage to the cost.
Darryl
Re: HKS pod, Microtech ecu, p/s pump... Sun, 12 September 2004 12:13 Go to previous messageGo to next message
Do you have those little plastic/rubber strips that go between the headlight and the nosecone when the lights are down?
What about a good condition lower half of the front bar?
The little brace that sits in the middle of the rear sunshade?
deltathing
adelaide
Re: HKS pod, Microtech ecu, p/s pump... Mon, 13 September 2004 01:18 Go to previous messageGo to next message
I'll take the HKS pod, if you will post it to adelaide..
pm me
bbaacchhyy
Re: HKS pod, Microtech ecu, p/s pump... Mon, 13 September 2004 02:33 Go to previous messageGo to next message
Hiya,
If Ed hasn't snaffled them, I have a mate interested in the front D/side blinker. What $ ?
Also after the front cowl panel that sits under the w/shield wipers. Available ?
Radio/ashtray surround. Available ?
Under dash plastic panel (drivers side that goes under the column). Available ?
Can't think of anything else particular at the moment.
Michael B
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Mon, 13 September 2004 04:00 Go to previous messageGo to next message
Darryl:
no light strips, no sunhade brace, not sure what you mean about "lower half of front bar"
Deltathing: it looks like the pod is already sold but ill get back to you
Bbaacchhyy: ill have a look for the blinker, no cowl panel, i have a radio surround but i think it has some small holes in it, i have the under dash panel in blue.
bbaacchhyy
Re: HKS pod, Microtech ecu, p/s pump... Mon, 13 September 2004 04:06 Go to previous messageGo to next message
STR8 2.8 wrote on Mon, 13 September 2004 14:00
Cheers.
Can you get pics of the radio surround ?
What is the underdash like ? Cracks ?
Any idea on prices - needs to be shipped to Adelaide.
Michael b
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Mon, 13 September 2004 05:01 Go to previous messageGo to next message
found the blinker housings but unfortunately discovered they both have cracks in them.
remembered the radio surround is not mine, it belongs to JAZE, so perhaps you should pm him and ask.
pic of under dash panel: http://members.optusnet.com.au/christopha/dashpane l.jpg
you can see the tab in the bottom left of the picture is broken otherwise the rest of it is in good nick.
as for postage, give me a postcode and ill have a look
bbaacchhyy
Re: HKS pod, Microtech ecu, p/s pump... Mon, 13 September 2004 05:07 Go to previous messageGo to next message
How bad are the cracks ?
I'll PM Jaze and ask him re the radio surround.
The postcode is 5034
Oooroo
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Mon, 13 September 2004 05:10 Go to previous messageGo to next message
they are salvagable, but not real pretty. ill get some pics.
postage for under dash panel would be around $8-10
p.s. the indicators are lenses only, no lights
[Updated on: Mon, 13 September 2004 05:25]
wilbo666
Re: HKS pod, Microtech ecu, p/s pump... Mon, 13 September 2004 09:56 Go to previous messageGo to next message
BlackSupra wrote on Sat, 11 September 2004 08:56
If you are interested in one that both opens and locks (as you prbly know the stock one will only lock, not unlock, pretty annoying if you have remote central locking), you could grab the actuator out of the rear left passenger door of a MX62 cressida (no idea but others might be same / similar). You will need to grind off the mounting tab bit that is held on with the two squashed stud things, and swap it with the stock MA61 one (yeah they are different). You'll also need to run and extra wire from the central locking relay if you want it to open as well tho!
Other wise if you can't find a MA61 actuator and really want one, I have one (without the tab) that works *not trying to steal someones sale tho*
BlackSupra
Re: HKS pod, Microtech ecu, p/s pump... Mon, 13 September 2004 09:58 Go to previous messageGo to next message
shit, id heard the didnt open, but thought that was just crap
well yeah im after open and close
ed_ma61
Lost in the K hole
Re: HKS pod, Microtech ecu, p/s pump... Mon, 13 September 2004 12:14 Go to previous messageGo to next message
whoa whoa whoa!!!
im still interested in Driver side front indicator lens Nod
(back the truck up there michael!! Laughing)
anyway - what ^^^^^ he said: pics of the cracked lens? mines got a hole in it the size of my finger, so its gotta be better than that.
bugger about the trim.
how about rear carpet from the boot area? black? decent condition?
ed
[Updated on: Mon, 13 September 2004 12:17]
wilbo666
Re: HKS pod, Microtech ecu, p/s pump... Mon, 13 September 2004 12:29 Go to previous messageGo to next message
BlackSupra wrote on Mon, 13 September 2004 19:58
yeah its teh gay. I made a spare MX62 one I had work the other day, so there is that option if you get keen (btw it wasn't rocket science! lol) Smile
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Wed, 15 September 2004 01:27 Go to previous messageGo to next message
Here is the indicator housing
http://members.optusnet.com.au/christopha/123_2304 .JPG
http://members.optusnet.com.au/christopha/123_2305 .JPG
http://members.optusnet.com.au/christopha/123_2306 .JPG
http://members.optusnet.com.au/christopha/123_2307 .JPG
http://members.optusnet.com.au/christopha/123_2308 .JPG
ed_ma61
Lost in the K hole
Re: HKS pod, Microtech ecu, p/s pump... Wed, 15 September 2004 02:00 Go to previous messageGo to next message
tell us the price, son!
also - any chance of a black boot carpet?
ed
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Wed, 15 September 2004 09:55 Go to previous messageGo to next message
dunno $10 maybe?
as for boot carpet..nay
i would like some myself actually (in blue)
STR8 2.8
Re: HKS pod, Microtech ecu, p/s pump... Thu, 16 September 2004 02:34 Go to previous message
righto, guess ill keep it then
Previous Topic:Fibreglass Racing Bucket - MELB
Next Topic:TRD valve springs FS:16v
Current Time: Fri Oct 23 04:53:53 UTC 2026
Total time taken to generate the page: 0.12406206130981 seconds
