Toymods » Tech & Conversions » SX Corolla idling at 1500rpm......help.
retro
SX Corolla idling at 1500rpm......help. Fri, 10 September 2004 11:02 Go to next message
Hey guys , 1990 SX idiling at 1500 rpm, all the time, any ideas what to change, hope you can help....urgent!
Cheers Skip
Scorpion
Menai area of Sydney
Re: SX Corolla idling at 1500rpm......help. Fri, 10 September 2004 12:32 Go to previous messageGo to next message
Do you have a stock air box ?
If so try blocking the tube from the front, top of the airbox to the top of the throttlebody.
Also try putting finger over hole in bottom of throttlebody entrance when the engine is at normal operating temp. If this lowers the revs then the idle control valve under the throttle body may be stuck.
retro
Re: SX Corolla idling at 1500rpm......help. Fri, 10 September 2004 12:48 Go to previous messageGo to next message
It is absoloutly stock as a rock........it's my dads car and he is 60.....so he definatly qualifies for old skool.....thanks for the tip, will try tomorrow.
Cheers skip
takai
Re: SX Corolla idling at 1500rpm......help. Fri, 10 September 2004 21:53 Go to previous messageGo to next message
Either that or if may be a vac leak.
RWDboy
Re: SX Corolla idling at 1500rpm......help. Sat, 11 September 2004 03:20 Go to previous messageGo to next message
Yeah i gotta try that trick on my GT4...it's idling stupid as well.
carsanactra
melbourne
Re: SX Corolla idling at 1500rpm......help. Sun, 12 September 2004 02:09 Go to previous messageGo to next message
*bump*
ive also got this problem, im idle at 1500rpm.
ive checked all my throttlebody connections, and they are fine. but when i start my car, i realised that my radiator fan is on from start.
im guessing this means that my theremostat thingy is buggered, and is probably the culpret for screwing up my idle?
Scorpion
Re: SX Corolla idling at 1500rpm......help. Sun, 12 September 2004 08:29 Go to previous messageGo to next message
After I did my engine conversion I had the fan on all the time.
There is an earth wire behind the fuse boxes in the engine bay. Make sure it is earthed properly - this fixed mine.
Leighp
NY
Re: SX Corolla idling at 1500rpm......help. Mon, 13 September 2004 03:54 Go to previous message
if all else fails: try adjusting the T/B by sticking a flat blade screwiw D in the hole in the back right hand side of the top (you will see where it goes, it is a large hole), have a friend in the drivers seat (while the car is idling) and turn the screw......one way the idle will raise, the other it will drop. but i do recommend that you check fully for leaks and missing hoses off that may have slipped off.
where are u located, i can help if you are a sydney-sider
Previous Topic:WHO uses spacers !? Need your opinion !
Next Topic:18r welsh plugs
Current Time: Fri Nov 20 15:55:32 UTC 2026
Total time taken to generate the page: 0.0047488212585449 seconds
