Toymods » Tech & Conversions » 4AGE reco head
macks
4AGE reco head Mon, 23 September 2002 01:52 Go to next message
Repco rang this morning to say that my poor corolla's head has three spots of corrosion and would cost $200ish to weld, skim and regrind affected valves. However, 4 intake and 6 exhaust valves aren't sealing particularly well, so to regrind those, resetting tappets etc and basically reco'ing the whole deal, I'll be up for $510. We're going to own the car for a while - so reco'ing is deemed "a good thing" - but I've gotta sus out some options first..
a) weld, skim, get back on road asap, think about selling it soon - $200
b) reco - $510
c) $x, buy already reco'd head from somewhere (where?)
d) $x buy non-reco'd but good cond 2nd hand head from somewhere (where?)
In addition, what opinions do people have about using ACL top end gaskets vs toyota top end gaskets?
cheers!
Rolla Boy
Club Member
Sydney, NSW
Re: 4AGE reco head Tue, 24 September 2002 16:18 Go to previous messageGo to next message
I'm getting a full head service (Sounds good huh Very Happy Very Happy Very Happy ) on my 4A-GE 100kW... I'm getting it skimmed flat at the bottom, a pressure test to make sure that it's okay and a full valve service which involves stripping the entire head and checking all the valves and valve caps for straightness and so forth... That's costing me:
$450 for the valve service
$67.60 for the pressure test...
You said that you're keeping the car for a while... Do the reconditioning... That way you can ensure that you should have no problems further on down the track... I'm doing a full engine rebuild and was thinking of skipping the valve service... But then I thought, "what if I put it all back together and one of the valves are infact bent or something is wrong with it"... That means that I'd have to pull it apart again, get that fixed and then put it all back together...
macks
Re: 4AGE reco head Wed, 25 September 2002 10:19 Go to previous message
yeah, went with the reco. The next problem I've just discovered is the surface of the block just underneath where the head corroded has pitted, right in the combustion seal bit so that's not cool Sad
Previous Topic:pitted block surface - repairable?
Next Topic:Differences between RA60 & RA65 struts?? Any takers
Current Time: Sat Nov 21 14:54:51 UTC 2026
Total time taken to generate the page: 0.0035159587860107 seconds
