Toymods » Tech & Conversions » How to test turbo shaft play?
Stefan
Hobart, Tas
icon5.gif  How to test turbo shaft play? Sat, 11 September 2004 14:34 Go to next message
Okay, I know at least one of my turbos is bad, blows smoke and puts oil throughout intake piping.
How exactly do you test shaft play/general turbo condition yourself? I've taken the intake pipes off each turbo - do I see if there is any wagglyability (ie, play) of the impeller along the shaft by poking throuhg the intake? Or should I unbolt the turbo from the manifold too?
EDIT: took pics:
http://www.speedtoys.com/~stefan/1G/turbo1.jpg
http://www.speedtoys.com/~stefan/1G/turbo2.jpg
http://www.speedtoys.com/~stefan/1G/turbo3.jpg
[Updated on: Sat, 11 September 2004 14:56]
joorsh
Re: How to test turbo shaft play? Sat, 11 September 2004 15:23 Go to previous messageGo to next message
Man that's a big mess around your poor turbo's Sad
I don't know much about testing for shaft play aside from the good 'ol wiggle test, but as far as I know shaft play doesn't lead to oil mess like that does it? Isn't that usually a seal problem if oil is leaking/burning?
-J-
Re: How to test turbo shaft play? Sat, 11 September 2004 15:42 Go to previous messageGo to next message
wiggle the shafts.
if there's more than 2mm waggle (approx) turbos are going, going, gone. As josh said, oil burning is due to seals going, but usually loose shafts is associated with seals going ([much like loose womend and stds)
nd o tyhanmote, avery drunk greg is going to get 3 hours sleep before tplatinh 5 hours of teenis tomorrow miogning.
I demand all of you pit me when you wake up... 'cais I'll have been at tennism for more than 4 hours alreatdy.
Stefan
Hobart, Tas
Re: How to test turbo shaft play? Sat, 11 September 2004 15:56 Go to previous messageGo to next message
Thanks guys.
Is it possible to have little play with bad seals, or not really, because if the seals have gone the turbos are most likely going too?
What are the likely causes for symptoms such as bad seals or seals+shaft play?
Stefan
Hobart, Tas
Re: How to test turbo shaft play? Sat, 11 September 2004 17:50 Go to previous messageGo to next message
Turns out that both turbos have about 1mm of play. The front one spins nice and freely and evenly - the back one, however, is gritty and hard to turn in one place (i.e., bearings)
Re: How to test turbo shaft play? Sun, 12 September 2004 07:26 Go to previous message
draven wrote on Sun, 12 September 2004 01:42
wiggle the shafts.
2mm is a shiteload of play for a turbo; if it's got that far it's well gone already! A tired turbo will have less play than that.
Previous Topic:dellortos going rich when i fang it?
Next Topic:WHITELINE AE86 SUSPENSION
Current Time: Sat Nov 21 20:39:40 UTC 2026
Total time taken to generate the page: 0.0068318843841553 seconds
