Toymods » Tech & Conversions » fuel leak and now blown turbo
Chris Davey
sunny coast, qld
icon13.gif  fuel leak and now blown turbo Sun, 12 September 2004 00:38 Go to next message
I am in the final stages of preparation before starting my new 1jz for the first time. And I now have a fuel leak? It is coming from the banjo bolt that connects to the fuel rail. It is circled in this pic.
http://pic15.picturetrail.com/VOL568/2504442/5190386/66456300.jpg
I have tightened this up as much as I can and it still leaks? Is there something I am missing here? I don't think it could be too tight.
Chris
[Updated on: Mon, 13 September 2004 03:14]
Maurice c
Re: fuel leak??? Sun, 12 September 2004 01:05 Go to previous messageGo to next message
This might seem like a silly question but have you used new washers on it and inspected the fuel rail and banjo bolt for defects. Also you night find out the exact torgue for the banjo bolt. Hope this helps.
Rallystanza
Re: fuel leak??? Sun, 12 September 2004 02:01 Go to previous messageGo to next message
Yeah i was gonna suggest the same, just check that your washers are all good. It could even be a fracture in the banjo itself??
Good luck
Jezza
Chris Davey
sunny coast, qld
Re: fuel leak??? Sun, 12 September 2004 02:07 Go to previous messageGo to next message
ok, will do.
Chris Davey
sunny coast, qld
Re: fuel leak??? Sun, 12 September 2004 03:04 Go to previous messageGo to next message
don't worry, it wasn't that banjo joint after all?
it was actually the regulator. All good now Smile
thanks guys Smile
Rallystanza
Re: fuel leak??? Sun, 12 September 2004 04:45 Go to previous messageGo to next message
Nice one glad ya sorted it out. Cool
Jezza
Chris Davey
sunny coast, qld
Re: fuel leak??? Sun, 12 September 2004 06:55 Go to previous messageGo to next message
off topic:
sorted that problem. Started the engine and it was going ok. Went to put my turbo pipes back on and dropped a bolt in the turbo inlet! Sad
Pulled the turbo off again and couldn't get the bolt out? For no reason I started wiggling the shaft and it has about 2mm of play in it and is scraping the housing! Sad
NOT A GOOD DAY!
Maurice c
Re: fuel leak??? Mon, 13 September 2004 01:37 Go to previous messageGo to next message
I'm not a turbo guru but I suspect that you need to get the turbo reconditioned and the bearings and seals replaced. Now is a better time then two months time when it breaks up. Get other opinions on this before acting though because I spend most of my time on diesels.
Re: fuel leak??? Mon, 13 September 2004 01:47 Go to previous messageGo to next message
A little off-topic, but where did that fuel filter come from? Did it come with the engine or did you put it there?
Chris Davey
sunny coast, qld
Re: fuel leak??? Mon, 13 September 2004 02:15 Go to previous messageGo to next message
that was the one that came with the soarer engine I bought. The other one I had on the chaser engine was a little different. We decided to use this one for no real reason in particular Smile
I am thinking more along the lines of single turbo upgrade now as I can't even remember how many times I have removed these turbos now and even with a rebalance and new seals etc. they are still little ct12a's. Which is a shame because I would have liked to have a crack at the quickest stock turboed 1jz in oz Smile
Now it is time to go looking for single turbo kits Smile
Re: fuel leak??? Mon, 13 September 2004 03:59 Go to previous messageGo to next message
Chris Davey wrote on Mon, 13 September 2004 12:15
You wouldn't happen to have the Chaser filter lying around would you?
Chris Davey
sunny coast, qld
Re: fuel leak and now blown turbo Mon, 13 September 2004 04:01 Go to previous messageGo to next message
sorry, I forgot which pic that was Smile
the one that is on that engine is the chaser one and it is a spare.
Re: fuel leak and now blown turbo Mon, 13 September 2004 04:44 Go to previous messageGo to next message
grrrr Mad
OK, if anyone has a fuel filter like that they'd like to sell (with associated fittings and hoses) please let me know. Smile
Bugman
Re: fuel leak and now blown turbo Mon, 13 September 2004 05:08 Go to previous messageGo to next message
cmon norbie.. go to a wrecker they'll give em away
Re: fuel leak and now blown turbo Mon, 13 September 2004 06:18 Go to previous messageGo to next message
Strangely enough Soarers aren't that common at wreckers, and I haven't seen a fuel filter exactly like that on any other Toyotas (eg Mk3 Supras are totally different)... but if you know of any please let me know!
Chris Davey
sunny coast, qld
Re: fuel leak and now blown turbo Mon, 13 September 2004 06:30 Go to previous message
to clarify: the one in that pic is the chaser one and it is a spare Smile
Previous Topic:voltage and audio crackles
Next Topic:TRX RIMS ON A KE70
Current Time: Fri Nov 20 18:40:47 UTC 2026
Total time taken to generate the page: 0.0072321891784668 seconds
