Toymods » Tech & Conversions » TRX RIMS ON A KE70
MR KE70
Parramatta
TRX RIMS ON A KE70 Sun, 12 September 2004 01:06 Go to next message
has any one done this
the two fronts hit the struts and i could told to get low profile tyres for 160 bucks but the rims are not even worth that.. so is there any thing i can do
http://img46.exs.cx/img46/5821/trx21.jpg
MR KE70
Parramatta
Re: TRX RIMS ON A KE70 Sun, 12 September 2004 01:07 Go to previous messageGo to next message
oh yeah it will cost 70 bucks for all 20 wheel nuts
blackRA28
adelaide
Re: TRX RIMS ON A KE70 Sun, 12 September 2004 10:36 Go to previous messageGo to next message
i run these rims on my ra28, with low pro's on the fronts.
i had to use 6mm spacers on the front and i used them on the rear too just to even out the track all round.
ae95
Re: TRX RIMS ON A KE70 Sun, 12 September 2004 10:46 Go to previous messageGo to next message
you only need 16 new nuts
you might need some bolt on spacers for the front OR longer studs and fit a spacer.
fitting a spacer with the stock studs isnt very safe because theyre so short.
schulzie
Re: TRX RIMS ON A KE70 Sun, 12 September 2004 10:52 Go to previous messageGo to next message
I have TRX rims on my ke70 wagon, 195/50/15 dont rub on my struts they are exrteemly close though. Any thing bigger in tyre width will rub, i did have 205/50/15 these rubbed but very little, only when suspension was fully compressed $70 for wheel nuts ? TRX rims are sposed to have a special wheel nut that only nissan made, very $$$. I bought some cheap mag wheel nuts with a fairly good taper on them, they dont hold on by much but its surely enough as ive had no problems with them.
SeptemberSquallIndustries
Re: TRX RIMS ON A KE70 Sun, 12 September 2004 11:00 Go to previous messageGo to next message
Quote:
the two fronts hit the struts and .. so is there any thing i can do
Buy rims with the correct offset?
ae95
Re: TRX RIMS ON A KE70 Sun, 12 September 2004 11:03 Go to previous messageGo to next message
yeah id suggest getting different rims, theyre not exactly the nicest wheel around. those tarago/celica/corona 14's fit well and are cheap
bmak
Re: TRX RIMS ON A KE70 Sun, 12 September 2004 12:16 Go to previous messageGo to next message
195/50/15 should be fine as thats what i used on my car.
You can get that size for $90 is the cheapest ive seen & about half for retreads.
I used normal mag nuts and added a taper in the lathe.
blackRA28
adelaide
Re: TRX RIMS ON A KE70 Mon, 13 September 2004 03:09 Go to previous messageGo to next message
yep my mate got me a set of new tapered wheel nuts to suit the nissan rims.
but yeh, im still on the lookout for some unique 15-16" rims with a more neutral offset, and some dish!
Laughing
MR KE70
Parramatta
Re: TRX RIMS ON A KE70 Mon, 13 September 2004 05:44 Go to previous message
trx looks hot so yeah.. i dont want to pay 160 for tyres so they might be selling
Previous Topic:fuel leak and now blown turbo
Next Topic:ae86 windscreen??
Current Time: Fri Nov 20 18:09:14 UTC 2026
Total time taken to generate the page: 0.022855043411255 seconds
