Toymods » Tech & Conversions » 4AGE smallport maximum compression on stock pistons
Phoenix01
Brisbane, Australia
icon5.gif  4AGE smallport maximum compression on stock pistons Sun, 12 September 2004 04:42 Go to next message
I'm sure this question has been asked before, but I did a search and came up with plenty of threads, but nothing answering my question. Embarassed
I'm going to have the head shaved, and my cams reground to 264 degree duration, 8.1mm lift. I'd like to know what sort of compression I can run before I have valves touching pistons. I'd like to be able to run 12:1 compression.
As the title says, the engine is a smallport 100kw 4AGE.
Thanks in advance. Smile
Hunty
Re: 4AGE smallport maximum compression on stock pistons Sun, 12 September 2004 05:23 Go to previous messageGo to next message
reground??? YIKES
get sum billets man they're not THAT expensive
FKN16V
NSW, East Coast
Re: 4AGE smallport maximum compression on stock pistons Sun, 12 September 2004 06:14 Go to previous messageGo to next message
Hunty wrote on Sun, 12 September 2004 15:23
reground??? YIKES
I agree, i have a link to a pic of what happens to re-ground cams, when i find it ill email it too you. Try wade cams in melbourne.
Steve
Phoenix01
Brisbane, Australia
Re: 4AGE smallport maximum compression on stock pistons Sun, 12 September 2004 06:22 Go to previous messageGo to next message
Fair enough... I'll look into getting some new cams instead. Thanks for the info. Smile
Still need to know what my limits are for shaving the head. I'd love 12:1 compression. Very Happy
ae86drift
sydney.au
Re: 4AGE smallport maximum compression on stock pistons Sun, 12 September 2004 07:01 Go to previous messageGo to next message
running compression that high
you'd want to be using 98octane fuel
Phoenix01
Brisbane, Australia
Re: 4AGE smallport maximum compression on stock pistons Sun, 12 September 2004 09:47 Go to previous messageGo to next message
Yeah, I've only ever used 98 octane (BP Ultimate) in this thing... I had the timing advanced while on the dyno, so it's kinda 'tuned' for 98 octane anyway.
batteryman
Re: 4AGE smallport maximum compression on stock pistons Mon, 13 September 2004 03:36 Go to previous messageGo to next message
With that compression I'd be worried about pinging if your still using the factory computer.
Phoenix01
Brisbane, Australia
Re: 4AGE smallport maximum compression on stock pistons Mon, 13 September 2004 12:54 Go to previous messageGo to next message
Thats where a bigger fuel pump and a malpassi come in. Very Happy
batteryman
Re: 4AGE smallport maximum compression on stock pistons Mon, 13 September 2004 23:31 Go to previous messageGo to next message
A bigger fuel pump and more fuel pressure won't be enough.
Re: 4AGE smallport maximum compression on stock pistons Tue, 14 September 2004 03:55 Go to previous messageGo to next message
I'm thinking that's a bit of an ambitious head shave... remember it's going to screw with your cam timing a little bit too... but then you'd be fixing up your cam timing because you're changing cams.. right! Cool
Also, 12:1 is doable, but it's not going to be happy with factory timing/fuel. As a guide, the old group A 4AG's ran 12:1, 300ish cams, rechipped (in Japan) factory ECU and made ~195hp on Avgas.
PyRoMaNiAc
Kings Langley, Sydney
Re: 4AGE smallport maximum compression on stock pistons Wed, 15 September 2004 02:59 Go to previous message
is there any info on these old group a 4ag's
are these the same ones that they used at bathurst in the early 90's!!
i want one Razz
Previous Topic:1jz manual into 88 soara
Next Topic:Another 5mge wiring question
Current Time: Fri Nov 20 12:33:12 UTC 2026
Total time taken to generate the page: 0.0064640045166016 seconds
