Toymods » Tech & Conversions » 1jz manual into 88 soara
rozz
1jz manual into 88 soara Sun, 12 September 2004 07:44 Go to next message
just wondering if anyone out there has put a 1jz from a new soara into an older shape one. eg.88 model.
if anyone has its it a hassel or a pretty easy conversion
any good suggestions for a work shop to do it in QLD
BlackSupra
Re: 1jz manual into 88 soara Sun, 12 September 2004 07:51 Go to previous messageGo to next message
yes its been done.
Buy a JZA70 halfcut and swap over the crossmembers.
No engine conversion is easy, some just piss you off less.
No idea about workshops
Danish
Re: 1jz manual into 88 soara Sun, 12 September 2004 08:06 Go to previous messageGo to next message
www.users.bigpond.net.au/soarer
rozz
Re: 1jz manual into 88 soara Tue, 14 September 2004 09:09 Go to previous messageGo to next message
well is this conversion one that piss u off lots or just a bit
BlackSupra
Re: 1jz manual into 88 soara Tue, 14 September 2004 09:22 Go to previous messageGo to next message
can't say, haven't done one....
however if you start with a jza70 halfcut that will make it alot easier
7M-Brisbane
Re: 1jz manual into 88 soara Tue, 14 September 2004 09:35 Go to previous messageGo to next message
Hi Rozz
Your best option is to DIY, and I'm sure there are people on the forums that will give you a hand if you get stuck. Any engine conversion is an expensive and long process, and will cost you about three times as much as you originally envisage - no matter how diligent you are or how many engine conversions you have done before.
My current conversion is a 1JZGTE into a '76 Mark II. I am a DIY guy, but there are always things you need done by other people (eg. some people don't like working on suspension, or don't have the tools for certain jobs) that hold you up. In my case I have been held up for almost 3½ months so far, and the workshop in question still hasn't turned a spanner on the car. This is for a variety of reasons, and not really anyone's fault, but this is all time that the car ends up off the road. Obviously people don't normally get held up to THIS extent, but it pays to hilight extra difficulties (and associated expenses) that may pop up.
Expect to pay around $10,000 to pay someone to do the conversion. You can probably save about $4,000 by DIY.
Chris Davey
sunny coast, qld
Re: 1jz manual into 88 soara Tue, 14 September 2004 11:08 Go to previous messageGo to next message
3 months is nothing!
bought car half done in feb 03 got it on the road Feb 04. on the road for 3 months till May. back off the road until about December most likely Smile
dingaling
tas
Re: 1jz manual into 88 soara Tue, 14 September 2004 13:17 Go to previous messageGo to next message
I don't reckon my engine conversion will cost much more then the halfcut + frieght and an oil/coolant change. Yeah that's a pretty bold statemend i know.
I figure a Ma70 conversion to 1jz-gte is mostly all bolt in with minimal to no custom workd needed. maybe do the timing belt while the engine is out, if it's not leaking anywhere and the engine isn't a crapper to begin with i'll skip the engine freshen up and simply buy another bare 1jz engine wich are going quite cheap.(when/if the existing 1jz craps out) Main thing is having the JZA platform for the future 2jz-gte conversion! now that will cost abit!
Of course i plan to do it myself to save as much $$ as possible.
Re: 1jz manual into 88 soara Tue, 14 September 2004 13:27 Go to previous messageGo to next message
dingaling wrote on Tue, 14 September 2004 23:17
Yeah, you're not the first person to think that.
Good luck! Smile
dingaling
tas
Re: 1jz manual into 88 soara Tue, 14 September 2004 14:14 Go to previous messageGo to next message
well if i pull it off and have a ma70 with 1jz that drives for the costs i listed above maybe then i can command some RESPECT around here!
ha but in all seriousness thanks for the good luck i'll need it no doubt.
will let you know how i go.
7M-Brisbane
Re: 1jz manual into 88 soara Tue, 14 September 2004 16:21 Go to previous messageGo to next message
That's three months just for the steering to be done (or not done, as the case still is)! The car itself has been off the road since 26th January (engine removed same day) and I reckon it'll be on the road about that time next year!
What about the clutch? Water pump (if ditching fluid fan)? Servicing items like rear main seal, cam belt, tensioner if needed, spark plugs? Engineering costs? Considered the tailshaft (yoke is the same, not sure on length though)?
But yes you're right and everyone else that's done engine conversions is wrong Shocked
[Updated on: Tue, 14 September 2004 16:23]
Chris Davey
sunny coast, qld
Re: 1jz manual into 88 soara Tue, 14 September 2004 21:41 Go to previous messageGo to next message
7M-Brisbane wrote on Wed, 15 September 2004 02:21
ooooh ok then. That's alright Razz
dingaling
tas
Re: 1jz manual into 88 soara Wed, 15 September 2004 03:00 Go to previous message
7M-Brisbane: did you read my whole post or just copy Norbie?
"I figure a Ma70 conversion to 1jz-gte is mostly all bolt in with minimal to no custom workd needed. maybe do the timing belt while the engine is out, if it's not leaking anywhere and the engine isn't a crapper to begin with I'LL SKIP THE ENGINE FRESHEN UP and simply buy another bare 1jz engine wich are going quite cheap.(when/if the existing 1jz craps out) Main thing is having the JZA platform for the future 2jz-gte conversion! now that will cost abit!"
Ok i would include engine mounts and if whatever needs replacing for the engine to work, otherwise it'll be just like the car in japan before it left for australia -thrashed! but hey i'm cheap.
now get off your pony.
Previous Topic:st184/st185 instrument cluster info
Next Topic:4AGE smallport maximum compression on stock pistons
Current Time: Fri Nov 20 12:49:13 UTC 2026
Total time taken to generate the page: 0.010798931121826 seconds
