Toymods » Tech & Conversions » Celica 3SGTE into an MR2
MR2_On_Boost
Celica 3SGTE into an MR2 Sun, 12 September 2004 20:52 Go to next message
Blew up my 3s a few weeks ago and after much stuffing around the mechanic has finally told me that he got the wrong engine. Mad He said there is no way of changing it to fit my MR2 (SW20 1993 GT). Since his big stuff around and delays to finishing my car i thought i'd double check here to see if anyone knew otherwise. Thanks
Joshstix
Toymods Vice President
Re: Celica 3SGTE into an MR2 Sun, 12 September 2004 22:24 Go to previous messageGo to next message
As long as the engines are both the same generation, the basic block is the same. All of the external components can bolt onto each block so it should be possible to convert the GT4 engine to use ing the MR2.
If the engine he bought is from a ST165 then I don't think the manifolds etc will bolt up and you wouldn't want to use the engine anyway as it is a far inferior example.
MR2_On_Boost
Re: Celica 3SGTE into an MR2 Sun, 12 September 2004 22:44 Go to previous messageGo to next message
he said something about the crankshaft being different and thats all really
Joshstix
Re: Celica 3SGTE into an MR2 Sun, 12 September 2004 23:19 Go to previous message
Well the only way the crank shaft interacts with the externals of the engine is with the bolting on of the flywheel and the crank pulley.
The flywheel will work for either car as they use essentially the same gearbox. The crank pulley is different between the two but can be swaped easily enough.
I'd advise going back and getting a better explanation and if he can't give one then I'd be looking for a better mechanic.
Previous Topic:Where to get a celica sprayed in CBR???
Next Topic:hilux engine options (help)
Current Time: Fri Nov 20 14:10:04 UTC 2026
Total time taken to generate the page: 0.0055620670318604 seconds
