Toymods » Tech & Conversions » very ill 4age
jaydik
icon9.gif  very ill 4age Mon, 13 September 2004 01:11 Go to next message
my 4ag in my 86 is sick as a dog, wondering if someone could help me determine the problem. Here are the symptoms:
* Plenty of white smoke out of the exhaust
* sounds like a rotor/wrx he he\
* traces of oil was found in the sparkies
The car still turns on but it takes a while and sounds like poo.
I'm thinking it's the piston rings, but any help would make the job easier.
cheers aussie 86
parrot
Re: very ill 4age Mon, 13 September 2004 02:21 Go to previous messageGo to next message
map sensor connected?
causinmayhem
Re: very ill 4age Mon, 13 September 2004 04:36 Go to previous messageGo to next message
ummmm... sounds a little worse than a map sensor.
possibly rings - but given that you said it doesn't sound good (i'm assuming you meant that) it will prolly be a little more in depth than JUST piston rings...
parrot
Re: very ill 4age Mon, 13 September 2004 04:37 Go to previous messageGo to next message
Maybe.... Disconnect the vacuum line one day and see how bad it is!
hotrolla
Re: very ill 4age Mon, 13 September 2004 05:06 Go to previous messageGo to next message
Could be that your head gasket is blown or your only running on 3 cylinders
ae95
Re: very ill 4age Mon, 13 September 2004 05:45 Go to previous messageGo to next message
inspect plugs, if they look like they are dirty/corroded then replace
check that all sparkplugs are getting a spark, could be dizzy points too
[Updated on: Mon, 13 September 2004 05:46]
davedave
Re: very ill 4age Mon, 13 September 2004 05:57 Go to previous messageGo to next message
Could be a few things,
When did it start doing it? What were you doing before hand?
It sounds like one or two of your cylinders isn't firing. If you were driving and all of a sudden noticed a loss of power and it idling like a harley, then I'd say it's your head gasket. It's possible to blow a chunk out between a cylinder and a water track, which you'd notice water in your oil and vice versa. And it's possible to blow a chunk out between cylinders, which you'd have no water in your oil, but no compression and hence no firing on two of your cylinders.
Or, If you just washed your car (and engine) you might have a well of water in your plug holes.
Or, If you've had the leads off, you might have them around the wrong way.
If you had done nothing before and it happened all of a sudden, my money would be on the head gasket. Most electrical problems happen intermitantly before becoming a full blown problem.
Dave
cri_ag
northern beaches
Re: very ill 4age Mon, 13 September 2004 08:18 Go to previous messageGo to next message
same symtoms as when the 4ac did a head gasket, so thats my guess.
FKN16V
NSW, East Coast
Re: very ill 4age Mon, 13 September 2004 10:20 Go to previous messageGo to next message
cri_ag wrote on Mon, 13 September 2004 18:18
I can vouch for that fact,
Im not 100% sure whats wrong with the 4age but im betting no ignition of fuel for whatever reason, blown head gasket or busted dizzy.
Re: very ill 4age Mon, 13 September 2004 12:19 Go to previous messageGo to next message
isn't anyone going to suggest "do a compression test" ??
davedave
Re: very ill 4age Mon, 13 September 2004 20:47 Go to previous messageGo to next message
Hidden in a message criticising everyone elses responses, I guess you just did Smiley =
Re: very ill 4age Tue, 14 September 2004 09:16 Go to previous messageGo to next message
LOL Laughing , well someone had to suggest it eventually Wink
it's one of the first tyhings i do when i suspect a motor is sick.. and it's as easy as removing spark plugs...
Cyber-punk
Brisbane, QLD
Re: very ill 4age Tue, 14 September 2004 09:50 Go to previous messageGo to next message
the plugs on my stupid engine take effort(removing intake pipe)
so its not THAT easy Razz
sort of on topic
when other people have experienced a blown head gasket, did the engine shake around alot?
Conquest
Sydney/Wollongong
Re: very ill 4age Tue, 14 September 2004 12:50 Go to previous messageGo to next message
davedave wrote on Mon, 13 September 2004 15:57
When did it start doing it? If you had done nothing before and it happened all of a sudden, my money would be on the head gasket.
That's what happened to me, engine was running fine one day & barely running the next.
I had a similar symptoms with my 4AFC, white smoke/steam from the exhaust, really hard to keep a steady idle, sounded like a 2 stroke and had no power (nah, that last part was normal). Suspected blown head gasket...
And Cyber-punk, yep mine did.
[Updated on: Tue, 14 September 2004 13:06]
jaydik
Re: very ill 4age Wed, 15 September 2004 07:16 Go to previous messageGo to next message
actually i lost power all of a sudden and the car was choking to stay idling, then it just konked out. there was no oil in my radiator, but i haven't had time to pull it apart.
spirokeet
London
Re: very ill 4age Wed, 15 September 2004 08:36 Go to previous message
My 4age was idling really rough due to a cracked injector seal, but the white smoke tends to point to oil being burnt.
Generally smoke on acceleration means rings, on decelleration (engine braking) means valve seals.
That's what i've been told, anyway
Previous Topic:5MGE sump?
Next Topic:Fitted MBC but fuelcut kicks in??
Current Time: Mon Oct 26 08:43:25 UTC 2026
Total time taken to generate the page: 0.0091609954833984 seconds
