Toymods » Tech & Conversions » 1ggte sump removal
Dust
1ggte sump removal Mon, 13 September 2004 02:04 Go to next message
Just managed to get the engine and g/box out of the halfcut (by myself) and put the engine on a stand, I have undone all the nuts and bolts to get the sump off but it wont budge, any tricks to it?
Help appreciated
Dust
Chris Davey
sunny coast, qld
Re: 1ggte sump removal Mon, 13 September 2004 02:12 Go to previous messageGo to next message
if it is like my 1jz it had some silicone type stuff sticking it together. We just pried it apart with a screwdriver and eventually it will come off.
good luck
Dust
Re: 1ggte sump removal Mon, 13 September 2004 02:26 Go to previous messageGo to next message
hehe thanks, that was my next approach, just thought I would check to make sure there wasnt some sort of trick to it Smile
Stefan
Hobart, Tas
Re: 1ggte sump removal Mon, 13 September 2004 03:37 Go to previous messageGo to next message
Out of interest, what halfcut is it, and what are you putting the IGGTE into?
Dust
Re: 1ggte sump removal Mon, 13 September 2004 04:25 Go to previous messageGo to next message
its a 1990 chaser half cut, putting into 2wd hilux.
Need the sump off so I can get custom one made up.
Stefan
Hobart, Tas
Re: 1ggte sump removal Mon, 13 September 2004 04:51 Go to previous messageGo to next message
Dust wrote on Mon, 13 September 2004 14:25
Surely you can swap sumps with someone else? Or do neither the front, mid, and mid/rear suit a hilux crossmember? If one of them goes, then you can just swap sumps & pickups with someone.
What engine did the hilux have - 22R? If so, what are you doing about mounts?
Bugman
Re: 1ggte sump removal Mon, 13 September 2004 05:07 Go to previous messageGo to next message
yeah, cos if its a 22r-e hulix a front sump should solve it.
though you may need a custom sway bar.
indian
south east - melbourne
Re: 1ggte sump removal Mon, 13 September 2004 06:12 Go to previous messageGo to next message
out of curiousity , does anyoe know what box is in the 1g-gte automatic tranny the name of the box preferably and model number , need to find some parts for it for tranny service
Dust
Re: 1ggte sump removal Mon, 13 September 2004 07:53 Go to previous messageGo to next message
its an 83 hilux, 18r engine.
not sure on engine mounts yet, but I am documenting my conversion with pics, will post it when I am done.
matt_84
Ipswich
Re: 1ggte sump removal Mon, 13 September 2004 08:09 Go to previous messageGo to next message
The auto is an a340e i'm pretty sure.
indian
Re: 1ggte sump removal Mon, 13 September 2004 22:45 Go to previous messageGo to next message
thanks someone else siad the same so hopefully it is
Fattony
Re: 1ggte sump removal Tue, 14 September 2004 07:09 Go to previous messageGo to next message
Back to the original question if you havnt got the sump of yet try heating up whats sealing it, would make it a lot easeir to get off.
dcving
newcastle nsw
Re: 1ggte sump removal Tue, 14 September 2004 23:15 Go to previous message
dust, for engine mounts on your conversion, get two (cant remember if its drivers or passenger side) engine mounts off the 18r elongate the holes slightly and it will bolt in.
you will also have too shorten the intake pipes to the plenum by 100mm, gearbox crossmember also needs too be modified Very Happy
just a few handy hints, any other questions just pm me, relatively straight forword conversion though Smile
Previous Topic:1jz wish list
Next Topic:Slotted rotor direction
Current Time: Fri Nov 20 09:54:50 UTC 2026
Total time taken to generate the page: 0.017169952392578 seconds
