Toymods » Tech & Conversions » 2stroke in engine
scano
2stroke in engine Mon, 13 September 2004 09:25 Go to next message
IF i ran my car on 5lt of 2stroke to get to a servo could i have done some sort of damage to it, or will i have lost a great deal of power?
Re: 2stroke in engine Mon, 13 September 2004 09:33 Go to previous messageGo to next message
Theres no problem doing this at all. Think about the fuel used in private planes, its basically a 2-stroke mixture.
brett_celicacoupe
townsville NQLD
it is likely to just blacken the plugs. and give the top end extra lubeing Razz
might smoke a little too hehehe
i cant see any damage being done
scano
Re: 2stroke in engine Mon, 13 September 2004 09:39 Go to previous messageGo to next message
jsut asking the question cause i used 2stroke to fuel my car just as i did a minute burnout on oil, and now its running reallly rough, just trying to narrow down the problem, i changed the sparks and checked the timing and it all seemed to be fine but the car is running really rough
Re: 2stroke in engine Mon, 13 September 2004 12:48 Go to previous messageGo to next message
Cool1 wrote on Mon, 13 September 2004 19:33
WTF? "Private planes" (I assume you mean light planes) run on Avgas which doesn't resemble 2-stroke at all...
pheonix83
Devonport Tasmania
Re: 2stroke in engine Mon, 13 September 2004 12:55 Go to previous messageGo to next message
sounds like your plugs are a little fouled
Re: 2stroke in engine Tue, 14 September 2004 10:51 Go to previous messageGo to next message
Norbie wrote on Mon, 13 September 2004 22:48
You've never heard of people mixing their own fuel? Caster oil?
Re: 2stroke in engine Tue, 14 September 2004 10:56 Go to previous messageGo to next message
scano wrote on Mon, 13 September 2004 19:39
hmm sound slike you fucked your engine by runnign ti on 2 stroke and trying to do a burnout....
live and learn perhaps?
Re: 2stroke in engine Tue, 14 September 2004 11:54 Go to previous messageGo to next message
Cool1 wrote on Tue, 14 September 2004 20:51
Yes I have, but how does that make 2-stroke the same as Avgas?
Re: 2stroke in engine Tue, 14 September 2004 11:59 Go to previous messageGo to next message
Theres nothing special about avgas, its just cleaner(more refined). Avgas+caster oil= 2 stroke mixture.
Also a few years ago avgas was not available to everyone so pump fuel and caster oil is all that was used. In fact a guy at my work still uses pump fuel and caster oil in his cesner(spelling?).
Re: 2stroke in engine Tue, 14 September 2004 12:05 Go to previous messageGo to next message
Um, I suggest you go to a fuel distribtor's web site (eg www.bp.com.au) and read up on the specs; Avgas is and always has been totally different to pump fuel. The main difference is Avgas has shiteloads of lead in it, which is why it has way higher octane than pump fuel!
Re: 2stroke in engine Tue, 14 September 2004 12:22 Go to previous messageGo to next message
castor oil/methanol/nitromethane is commonly used for MODEL aviation fuel.
mixing castor oil with petrol, is in a way similar to mixing petrol and diesel/kerosene. the slow burning characteristics of avgas might be recreated by slowing down the petrol burn rate with the castor oil.... (remember, it's not all about octane rating..(ie detonation resistance) it's about burn rate as well)
since planes generally have large bores and low rpm, they need a fuel that will burn evenly and not have an accelerating flame front, (which, when it collides witht he cylinder wall, pings). avgas is designed to be both detonation resistant AND slow burning...
not to say all the race kiddies using avgas are wrong, but they may need to up the advance significantly to take advantage of it(or up the compression ratio and heat to increase burn speed)
but anyway, we have digressed.. again Wink
2 stroke will just make smoke and deposit carbon in your motor.. you may also find the oil gums up in your fuel lines and carby.
ppl have accidentally filled new cars with diesel and survived, so why would a bit of oil kill your motor (and isn't that the norm for old corollas anyway Razz Laughing )
if your motor died, it's more likely the abuse from the burnouts.
no offence intended but.....
burnouts on oil = fried motor = idiot in my books Wink
and it's cessna Wink
Re: 2stroke in engine Tue, 14 September 2004 12:25 Go to previous messageGo to next message
as above.
2 stroke wont kill a motor.
but I mean really, if you've put a bit of 2-stroke in your car to get it somewhere and you know it's not supposed to be in there, was it really a good idea to do a burnout running it?
Re: 2stroke in engine Tue, 14 September 2004 12:45 Go to previous message
oldcorollas wrote on Tue, 14 September 2004 22:22
Caster oil mixtures was all that was used in real planes a fair few years ago(you may not be old enough to know this) and it still used a fair bit these days.
Previous Topic:Buying Imported Engine - What would you do before installing it?
Next Topic:jza70/jzx90 intercooler
Current Time: Fri Nov 20 11:43:11 UTC 2026
Total time taken to generate the page: 0.04598593711853 seconds
