Toymods » Tech & Conversions » 18rgeu valve and cam questions
people100
Rocklea qld
18rgeu valve and cam questions Mon, 13 September 2004 11:12 Go to next message
Ive found number 3 ad 4 intake valve to be bent now ive stripped my head and i wanna know what other damage could have happened. doesnt seem to have damged the guides etc that i can see. How do i tell if number and 2 could be bent. they had compression of around 120psi in each when tested.
Also whats the best suitable engine to get bigger(oversize valves) from or what brand should i get for it and prices etc if i decide to just go oversize.
How much difference is in the 88270 cams and the 88250 cams. which would be the better cams to run in a 18rgeu with turbo. Im looking to get best performance. Or should i run 88270 intake and 88250 exhaust or the other way around. Ive been told i need to try to remove any valve overlap so i dont loose compression out the exhaust when im on boost
[Updated on: Mon, 13 September 2004 11:28]
brett_celicacoupe
townsville NQLD
Re: 18rgeu valve and cam questions Mon, 13 September 2004 23:53 Go to previous messageGo to next message
talk to mrdohc, he put oversize valves in his rg head cant remeber what they were made out of though
RT104GT
Western Victoria
Re: 18rgeu valve and cam questions Tue, 14 September 2004 00:01 Go to previous messageGo to next message
How did you ever bend valves in an 18rg? I used to rev mine to redline for years and never bent a valve even when the timing chains used to rattle during oil bleed up?? Shaun Maloney has all my shims so can't assist in that area..
people100
Rocklea qld
Re: 18rgeu valve and cam questions Tue, 14 September 2004 00:14 Go to previous messageGo to next message
i dont know how they got bent...i bought the head so i had the proper efi one. They may have been damaged before i got it but i didnt see anything wrong with it.
RT104GT
Western Victoria
Re: 18rgeu valve and cam questions Tue, 14 September 2004 01:02 Go to previous messageGo to next message
OK understood. Shit happens.. Heads are bullet proof get two used or new valves and lap them in lightly by hand. Shims may be a problem so note which shim comes off which valve and mark it. Shaun maloney has a full set of my old unused shims if you need them. Phone number in the forum eslewhere. You should be able to get the ehad fixed pretty quickly dont reinvent the wheel. We had my engine pulled down and one dickhead was cleaning the pistons and dropped one and broke the skirt. We found another second hand piston that miked up well and its been in since 100,000 for 140,000 like I said engines are pretty strong. 2 cents
people100
Rocklea qld
Re: 18rgeu valve and cam questions Tue, 14 September 2004 02:01 Go to previous messageGo to next message
yeah im currently trying to hunt down 2 second hand valves but have had no luck yet...Do u know if the 88250 heads and the 88270 heads are the samd design as in can i get another 88250 head and put my 88270 valves, valve springs and cams in or do the valves not fit. Its just i have a little corossion around the water ports which im a bit scared of. I can get it fixed but then they will need to take to much meat off the head to flatten it and i dont wanna raise the compression. Im trying to lower it.
RT104GT
Western Victoria
Re: 18rgeu valve and cam questions Tue, 14 September 2004 02:14 Go to previous messageGo to next message
I will check through my stuff but not sure if I have any valves maybe inlet unsure.
Yeah watch the skimming been there done that with datto head now suffer long oil gallery pump up time not to mention in Toyota head that only valve clearance adjustment is by shims and you won't have any.
Stephos site is best for the head types he has all the knowledge you need.
wstephenson@qrsciences.com
web Twisted Evil site
http://ourworld.compuserve.com/homepages/stepho/ho mepage.htm
RT104GT
Western Victoria
Re: 18rgeu valve and cam questions Tue, 14 September 2004 02:17 Go to previous messageGo to next message
TOYAPARTS are now TOYA DATTO in Melbourne that guy has all the latent knowledge from the twin Cam development era of 1980-1985.
I gave them all my spare engine stuff about 20 years ago.
Dont know what 18RG stuff is still a round.
Do an engine search on the Google engine you may find some stuff but highly priced.
blackRA28
adelaide
Re: 18rgeu valve and cam questions Tue, 14 September 2004 03:33 Go to previous messageGo to next message
Okay when i bought my 18Rgeu it had bent valves.
Dont know how cos the previous owner said it went very well, but when we pulled it apart the top timing chain was very stretched and a couple of the inlets were bent.
new items were sourced thru Stewart Wilkins Motorsport.
later down the track i was driving the car at low engine speeds and the ex cam gear decided to snap the dowel holding the cam gear to the cam.
Pulled the head off again and noticed all ex valves bent. doh.
so more new valves sourced along with new valve springs throughout the head, put it back together and shes run fine havent had a problem with it(touch wood), and it is my daily driver.
this is my bent valve story.
RT104GT
Western Victoria
Re: 18rgeu valve and cam questions Tue, 14 September 2004 03:49 Go to previous messageGo to next message
Ouch dowelled cams to get better valve timing and anti pollution measures. You know the ball tearing 210 headed 18RGR engine cicrca 1974 had non of that crap it had basic high lift cams and a three bolt non geometrically adjustabale cam and revved like crazy. Then Yamaha got involved said yeah we make better heads, put in the dowelled cam with the single big bolt and flat washer, and it all went down hill. Lower revs less power..
RT104GT
Western Victoria
Re: 18rgeu valve and cam questions Tue, 14 September 2004 03:51 Go to previous messageGo to next message
Expert Shaun Maloney melbourne 03 9428 5277 65 Butler Street Rihmond Vic
Just looking at my compression rpessures scrawled into my engine book in 1976 170/175/172/175 cool huh..
people100
Rocklea qld
Re: 18rgeu valve and cam questions Tue, 14 September 2004 05:09 Go to previous messageGo to next message
are all rg and rgeu heads have the same valves???I did look on there just after it happened and only found a listing for 18rgu head valves. I may be on the look for a new head as i think the corrosion around the water ports is getting a little bad also
people100
Rocklea qld
Re: 18rgeu valve and cam questions Tue, 14 September 2004 05:10 Go to previous messageGo to next message
RT104GT wrote on Tue, 14 September 2004 13:51
I had 120 , 120 , 0 , 0
Not so cool huh
RT104GT
Western Victoria
Re: 18rgeu valve and cam questions Tue, 14 September 2004 05:47 Go to previous messageGo to next message
Early heads had softer valve seats as not designed for ULP.
But you are unlikely to find an earlier head.
if I get a chance I will check my head numbers.
Stepho is best bet send him and email or browse his page it has heaps of twin cam stuff.
people100
Rocklea qld
Re: 18rgeu valve and cam questions Tue, 14 September 2004 06:39 Go to previous messageGo to next message
who is stepho. im chasing a head in brissy but valves can come from anywhere. How much do u know about the oil pumps on them
RT104GT
Western Victoria
Re: 18rgeu valve and cam questions Tue, 14 September 2004 07:29 Go to previous messageGo to next message
Stepho runs the Toyota data site... http://ourworld.compuserve.com/homepages/stepho/ho mepage.htm
I know something of oil pumps there is a long discussion about them on the technical forum
engine codes and gearboxes at
http://ourworld.compuserve.com/homepages/stepho/en gcodes.htm
[Updated on: Tue, 14 September 2004 07:36]
RA40Celica
Hobart
  chris_rg@jabber.org
Re: 18rgeu valve and cam questions Tue, 14 September 2004 09:08 Go to previous messageGo to next message
RT104GT wrote on Tue, 14 September 2004 15:47
does this mean your saying early heads are unsuitable to run ULP (high octane). Some other people on this forum are of the opinion that because they have alloy heads the valve seats will already be hard enough for ULP.
i have 88210 head (early head) and run PULP (96 RON).
this is of particular interest to me because im running EFI on an early head and an o2 sensor. LRP will srew my o2 sensor, but i dont want my valve seats to get fucked either.
RT104GT
Western Victoria
Re: 18rgeu valve and cam questions Tue, 14 September 2004 09:28 Go to previous messageGo to next message
The 210 head on the twin cam from the 1973-74 series 18RG's were not efi they ran from dual solex sidedraft carbies at 9.7:1 with points ignition and were designed for high octane fuel 98 RON. That is my firm belief..you shoudl ask an expert maybe. Very few people know other than 1980 series Yamaha heads off efi model 18RGEU's. But some solex carbied 18RG's ame in from Japan at API Springvale.
RT104GT
Western Victoria
Re: 18rgeu valve and cam questions Tue, 14 September 2004 09:40 Go to previous messageGo to next message
I presume you run EFI, what timing settings??? Do you get any pinging?? Figures for timing the 210 head and camshaft assuming you have the early non dowelled camshaft are..
as follows..
PLUG heat range W20 or BP5
Plug GAP 1.00 mm
Dwell angle 50-54 degrees
Point gap 0.45mm
Static timing 5 degrees BTDC (engine stopped)
Cold engine 20 degrees BTDC (reference only)
Timing always set at 60 degrees Celsius when HOT engine 5 degrees per 1000 rpm BTDC.
Valve clearances 0.26 to 0.33 MM using shims. for Inlet
Exhaust is 0.31 to 0.36 MM cold.
Compression should be 185 PSI and if below 1`40 psi are crook valves or rings.
Head warp limit 0.050 mm
valve lap details
45 degrees angle
1.2 to 1.6 MM contact area if good condition.
There are four different colour inner valve springs.
etc etc
RA40Celica
Hobart
  chris_rg@jabber.org
Re: 18rgeu valve and cam questions Tue, 14 September 2004 09:59 Go to previous messageGo to next message
i've converted my engine from solex carbies to efi.
running 9.7:1 pistons, but with later dowelled camshafts (88250). ive got 160 +\- 5 psi on all cylinders. I would like to get hold of the original camshafts (210 or 230).
the cam timing is factory. well factory for those cams anyway. The notches are stright up at TDC compression stroke. I'm thinking i might play very slightly with this to see the effect.
i run premium unleaded and im not getting any pinging. Compared to carbies it has more torque down low with little effect up high.
For a daily driver it is sweet, starting perfect, runs good no matter what the wheather is doing, and you dont need an expert to tune it.
i tune it on the street using feedback from the seat of my pants and the o2 sensor.
you say ignition timing is 5 degree BTDC, i think ive seen 10degrees quoted elsewhere. with my combination i think its a matter of trial and error. Thats why im planning to get computer controlled ignition running aswell.
RT104GT
Western Victoria
Re: 18rgeu valve and cam questions Tue, 14 September 2004 11:00 Go to previous messageGo to next message
Just spoke to Steve Baird Toyota mechanic for 30 years and twin cam expert whilst he says he would not run the series on LPG that PULP PLUS upper cylinder lubricant additives is ok but timing is critical.
RA40Celica
Hobart
  chris_rg@jabber.org
Re: 18rgeu valve and cam questions Tue, 14 September 2004 11:11 Go to previous message
RT104GT wrote on Tue, 14 September 2004 21:00
when you say LPG do you mean LRP??
so he says PULP + upper cylinder lube is ok.
so when did the heads get harder valve seats, 88250 (18r-gu) and later???
ideally i would need 98 RON and upper cylinder lube.
Previous Topic:1jz limits
Next Topic:fuel filler neck
Current Time: Fri Nov 20 12:49:13 UTC 2026
Total time taken to generate the page: 0.0071637630462646 seconds
