Classifieds » Parts Wanted » MA70 Centre Tailshaft Bearing
KING_22
Oakleigh, Melbourne
MA70 Centre Tailshaft Bearing Tue, 14 September 2004 03:08 Go to next message
looking for this part for a friend. If anyone has one or does anyone know if toyota still sells them?
ed_ma61
Lost in the K hole
Re: MA70 Centre Tailshaft Bearing Tue, 14 September 2004 07:16 Go to previous messageGo to next message
repco has them - theyre about $70
KING_22
Oakleigh, Melbourne
Re: MA70 Centre Tailshaft Bearing Wed, 15 September 2004 03:16 Go to previous messageGo to next message
tried em here in melbourne and they didn't list them.
7M-Brisbane
Re: MA70 Centre Tailshaft Bearing Wed, 15 September 2004 08:52 Go to previous messageGo to next message
Having been there, I would suggest you look at getting a single piece tailshaft made. When my centre bearing played up I had one made for $140+GST IIRC.
Easier to work with, lighter, stronger, and generally cheaper than putting in a new centre bearing.
Trucks break tailshafts quite often, and there are a number of specialist businesses here in QLD. I'm sure that trucks also break in Victoria, so I'd be stunned if you couldn't locate someone to assist cheaply.
Allan
Re: MA70 Centre Tailshaft Bearing Wed, 15 September 2004 09:05 Go to previous messageGo to next message
ed_ma61 wrote on Tue, 14 September 2004 17:16
Ed!!! Part number??? repco has no listing down here
ed_ma61
Lost in the K hole
Re: MA70 Centre Tailshaft Bearing Wed, 15 September 2004 11:05 Go to previous messageGo to next message
ok, it wasnt repco, it was autobarn... my bad.
i shagged my bearing in dubbo, and the local autobarn had a massif tailshaft bearing book that they thunbed through to find me one for the ma61 supra.... it just happened that in the process of looking, we found a listing for the ma70 supra...
my ma61 unit had to be ordered in from the manufacturer/distributor...
perhaps try giving dubbo autobarn a call and get them to look through whatever that book is that they have there
KING_22
Oakleigh, Melbourne
Re: MA70 Centre Tailshaft Bearing Thu, 16 September 2004 02:42 Go to previous messageGo to next message
tried autobarn but they only have listing for MA60. Surely there is one out there that somone isn't using!
KING_22
Oakleigh, Melbourne
Re: MA70 Centre Tailshaft Bearing Thu, 16 September 2004 02:44 Go to previous messageGo to next message
7M: This is a bog stock chicks car with no intention of mods or anything. The labour cost involved in swapping to a single would not be whorth it for her. Thanks for the suggestion though man.
STR8 2.8
Re: MA70 Centre Tailshaft Bearing Thu, 16 September 2004 02:49 Go to previous messageGo to next message
a long shot i know...but are ma61 and ma70 centre bearings the same?
fractoid
Re: MA70 Centre Tailshaft Bearing Fri, 17 September 2004 13:04 Go to previous messageGo to next message
Meh... mine went a coupla years ago, and word then was they don't make them any more. I had to have mine rebuilt. Cost between $150 and $200 (can't remember exactly) - as Supra parts go, that's cheap. Smile
wilbo666
Re: MA70 Centre Tailshaft Bearing Sat, 18 September 2004 04:16 Go to previous messageGo to next message
7M-Brisbane wrote on Wed, 15 September 2004 18:52
Urgh, with an IRS diff tho, if you want to install/remove a 1 piece shaft you will have either the choice of removing engine and gearbox, or removing the differential setup..... Confused
(this is because the rear submember has a loop that the tailshaft goes through!)
7M-Brisbane
Re: MA70 Centre Tailshaft Bearing Sat, 18 September 2004 11:28 Go to previous messageGo to next message
Sorry but that's all incorrect.
An MA61 has a rear submember, and as such I would not have made this suggestion if we were discussing an MA61. We are instead talking about an MA70 which, like many other IRS cars, does *not* have a rear submember that the tailshaft travels though.
On an MA70 it is much easier to remove a single piece tailshaft - four bolts at the diff and it's out! The factory two-piece on an MA70 involves four bolts at the diff and two extra bolts for the centre bearing.
wilbo666
Re: MA70 Centre Tailshaft Bearing Sun, 19 September 2004 05:55 Go to previous message
7M-Brisbane wrote on Sat, 18 September 2004 21:28
I am duly chastised for my ignorance Smile
Previous Topic:Ma61 headlight switch. urgent will pick up tomorrow if in melbourne
Next Topic:TA22 strut brace
Current Time: Thu Oct 29 02:47:56 UTC 2026
Total time taken to generate the page: 0.037315845489502 seconds
