Toymods » Tech & Conversions » 5000km Service
rollaboy
Coffs
5000km Service Mon, 23 September 2002 12:57 Go to next message
I was just wondering what everone does for a 5000km service thats if you do one then??
Thanks Brett
Re: 5000km Service Mon, 23 September 2002 13:10 Go to previous messageGo to next message
I just change the oil and oil filter every 5000km. Every 20000km it goes to someone who knows what they are doing to check over things I miss. When I think of it I flush the coolant and replace it...thats about it.
MaNGeW
Formerly TRD_RoLLa
Re: 5000km Service Mon, 23 September 2002 14:47 Go to previous messageGo to next message
Yeh thats basically all i do. Oil and filter change every 5000kms. Check fluid levels. Usual stuff. Check ignition timing and spark plug condition. Check air filter. Maybe some injector cleaner. Check brake wear if im bothered.
Stuff u probably do already.
faulksy
Re: 5000km Service Mon, 23 September 2002 15:01 Go to previous messageGo to next message
yeah looks like everyone just does the basics. its all u should really need to. unless something unexpected pops up. it would cost way to otherwises and be fairly pointless
poombah
Forrestfield, WA
Re: 5000km Service Mon, 23 September 2002 16:19 Go to previous messageGo to next message
Dont forget coolant... always overlooked..
Check your coolant (ie if its toyota it better be RED)..
you can get testers that test the strength, usually you want from 50/50 to 60/40 is the standard ranges in most cars. Make sure the overflow bottle is at its (MAX) mark and the water in the radiator appears clean.
Check radiator cap to make sure seal is still good.. have a close look at the top tank (most toyotas are plasic from the late 80's onwards) for signs of stress/cracks/seeping.
Also check thermostat housing and heater hosing.
TCHOON
Sydney- Sutho Shire &...
Re: 5000km Service Tue, 24 September 2002 09:40 Go to previous messageGo to next message
ditto, and replace; fuel filter 50000, timing belt 100000, & air filter about 20000 give it a look.
GIN51E
Berowra-Sydney
Re: 5000km Service Tue, 24 September 2002 10:03 Go to previous message
shouldn't the points be changed every 12 months or doesn't that corrolla have points?
Previous Topic:re: surge tank
Next Topic:1jz gearbox into MZ61
Current Time: Sun Oct 25 13:50:17 UTC 2026
Total time taken to generate the page: 0.014855146408081 seconds
