Toymods » Tech & Conversions » Spark Plug Question
icon5.gif  Spark Plug Question Thu, 23 May 2002 12:49 Go to next message
Okay, as stated in another thread, I'm going to advance the timing and change the plugs in my 21R-C to take advantage of the fact I'm using 98RON fuel always instead of 89RON which its designed to cope with.
I've been told that I should go one range colder, can someone explain this?
Also, what brand of spark plug do people recommend? I was thinking about looking at the Iridium plugs by NGK or Denso. What does everyone recommend?
Re: Spark Plug Question Thu, 23 May 2002 12:50 Go to previous messageGo to next message
Also, feel free to comment in the other post:
http://www.toymods.org.au/msgboard/msg.php?th=436& amp;start=0&rid=162&S=108c8b09890cbfefac0c 42cec6032210
Re: Spark Plug Question Fri, 24 May 2002 01:31 Go to previous messageGo to next message
Anybody?
JIMMYD
Cairns
Re: Spark Plug Question Fri, 24 May 2002 03:08 Go to previous messageGo to next message
Generally a change to a colder plug is done to aviod detonation from increased compression, advancing timing(Combustion chamber hotter) or if evidence of overheating of the plug is apparent(usually caused by continuios high speed operation),just as a hotter plug is recommended in worn engines to avoid oil/carbon fouling.
When you remove a spark plug, what does the end look like? What colour is it? Does the ceremic look bleached/blistered?.
I have always had exceptional results from the NGK V groove range of plugs, the only brand (apart from Golden Lodge,N.L.A.) that has never let me down with dud plugs or premature failure.
James
Guest
Re: Spark Plug Question Fri, 24 May 2002 03:30 Go to previous messageGo to next message
You Can't beat the performance vs cost of a good old fasioned steel plug.
Platinum plugs simply do not perform as well!!
What do you think King_J runs in his 600+ HP techno-beast.
Re: Spark Plug Question Fri, 24 May 2002 04:46 Go to previous messageGo to next message
So what you recommend? Do I go colder because I'll be advancing the timing?
Mind you, going one colder will only mean I'd use the same heat range as the 5ME. And thats still pretty hot.
JIMMYD
Cairns
Re: Spark Plug Question Fri, 24 May 2002 05:18 Go to previous messageGo to next message
1.
Quote
Answer
Need to know what plug you are using now and what it looks like when removed from engine.
2.
Quote
Answer
MAY need to go colder, may not. It depends on your answer to 1.
James
Re: Spark Plug Question Fri, 24 May 2002 07:36 Go to previous message
Ok, I'll check how the plugs are now, if fine, advance the timing, then give it a little bit to see how they go...
I'll get the same heat range or a slightly colder one based on how the car reacts.
Thanks for the info.
Previous Topic:5sge?
Next Topic:trying to stop
Current Time: Sun Nov 1 05:45:32 UTC 2026
Total time taken to generate the page: 0.0047500133514404 seconds
