Toymods » Tech & Conversions » Solexs but what type?
SIKTA22
Solexs but what type? Wed, 15 September 2004 11:33 Go to next message
just picked up a set of solexs and i was wondering if any of you that have the same carbs can help me identify what some of the things on the carbies are ??
also need to know if it is safe to run without a vacume line to your carbs and still have your engine running good,idle good??
i dont know how to get pics up here though, can someone help me with that? im really lost on these carbs, very different to the usual 40PHH solexs.
thanks.
[Updated on: Wed, 15 September 2004 11:58]
grass hopper racing
australind w.a
Re: Solexs but what type? Wed, 15 September 2004 13:14 Go to previous messageGo to next message
Re Solex carbys I run twin 40mm on a 3t without the vacum connected and are now working better than the 45mm webbers that i had before.What sort of info are you chasing
SeptemberSquallIndustries
Re: Solexs but what type? Wed, 15 September 2004 13:22 Go to previous messageGo to next message
What vacuum? If you mean the vacuum advance for the distributor, then yes, it should be connected. Shocked
SIKTA22
Re: Solexs but what type? Wed, 15 September 2004 14:07 Go to previous messageGo to next message
grass hopper racing, i was looking for like an exploded view of these particular solexs that i have, i can send you pictures of them if youd like.. how is it possible that it works better with the vacume advance disconnected? but yeah just want to know if it will work..
SSI, yeah i mean the vacume advance from the dizzy to the carbs. i know it should be connected as on my old solexs, but these ones i have got now dont seem to have a place to put it onto or its either plugged up, there are a few bits of metal comming out of places as if it were blocked off, so maybe i can just run them without vacume adv connected?? strange though..
Re: Solexs but what type? Wed, 15 September 2004 14:13 Go to previous messageGo to next message
Maybe the car they were fitted to used a fixed advance curve or only mechanical advance. The 2T-G distributor is designed to use vacuum advance. Maybe if the port is soldered closed or something you could tap a fitting back in? Or take it from somewhere else?
allencr
tallahassee FL usOFa
Re: Solexs but what type? Wed, 15 September 2004 15:49 Go to previous messageGo to next message
solex has LOTS of models.
anything stamped into it?
the vacuum isn't really for the carb, it's for something that runs off of the carb, like the booster/servo or dizzy advance(nearly usless)or even a wind screen wiper motor.
the vacuum advance is really there to RETARD the ignition when the throttle is opened under a load.
SIKTA22
Re: Solexs but what type? Thu, 16 September 2004 00:32 Go to previous messageGo to next message
all i can see thats stamped on it is 21100-88254 on the sides of the carb.
SIKTA22
Re: Solexs but what type? Thu, 16 September 2004 11:15 Go to previous message
does anyone have any information about these sort of solexs, im pretty sure they are PPH versions so if anyone can scan me a picture of an exploded view of these carbs that would be great.
thanks.
Previous Topic:Tapper cover breathere hole.
Next Topic:KE30 Wheel alignment
Current Time: Fri Nov 20 11:57:46 UTC 2026
Total time taken to generate the page: 0.1489999294281 seconds
