Toymods » Tech & Conversions » 20v TPS Values
takai
20v TPS Values Wed, 15 September 2004 14:10 Go to next message
Heya guys
Just been calibrating the Microtech and for some reason the TPS wont go below 37%. Ive loosened off the TPS and adjusted it full one way, and set the correction to 99% and its still 37%, full the other way is 57%.
Anyone have some ideas?
Ben Wilson
Re: 20v TPS Values Wed, 15 September 2004 22:30 Go to previous messageGo to next message
I couldn't get Marks car to work on the 20v TPS (it just wasn't consistant enough), I'd suggest binning it and getting an aftermarket one.
Something like this would be ideal.
http://www.materials.unsw.edu.au/~sford/TPS.jpg
It appears the hotlinking isn't working, just go to www.farnell.com and search for "RESISTIVE SENSOR ROTARY"
[Updated on: Wed, 15 September 2004 23:35]
Re: 20v TPS Values Wed, 15 September 2004 23:21 Go to previous messageGo to next message
as a note, one of the MS guys got some of these as a group thng.. about $40 each Wink not sure if he can get more or has any left, but if you were local you could borrow mine to see what it reads...
i can get the resistance values if you want (if you tell me the angles your throttles go to)
maybe you could join up to the Aus and NZ forum of www.msefi.com and ask if anyone is local to you Wink
ae86trueno
Re: 20v TPS Values Thu, 16 September 2004 01:03 Go to previous messageGo to next message
must be a microtech thing, the 20V one worked fine with my EMS running full tps mode Razz ??
hows Marks new beast coming along Mr Wilson??
Ben.
AE86slut
Baulko Hillo
Re: 20v TPS Values Thu, 16 September 2004 01:07 Go to previous messageGo to next message
Seems to work fine with my Microtech.......
Ben Wilson
Re: 20v TPS Values Thu, 16 September 2004 01:28 Go to previous messageGo to next message
I think it just depends on the individual TPS, the Toyota one was very inconsistant. I think it was just worn out.
Marks Evo is coming along nicely, we're still trying to work out how to get it through a rego noise test with the anti lag and rotational idle...
gearb0x
Re: 20v TPS Values Thu, 16 September 2004 09:41 Go to previous messageGo to next message
tak i have the same as what ben linked to for my 2tg
The guy old corollas speaks of is local to me and i think he can get em easy enough if ya need
takai
Re: 20v TPS Values Thu, 16 September 2004 09:52 Go to previous messageGo to next message
Heh, well the car is coming your way tomorrow Ben. Well Canberra at least, as i promised.
Thats the only problem i had, i had it idling until i pulled the TPS off.
The TPS is pretty shot, only has two resistance values. Im getting a new one from Mal.
See you up there.
10sec_rx7
Syndey
Re: 20v TPS Values Fri, 17 September 2004 06:53 Go to previous messageGo to next message
ive never had a problem with any stock toyota tps's on microtechs, have lots of problems with ford ones tho as they are all worn out!
have to calabrated the tps?? if so you have it wired wrong.
Dale
takai
Re: 20v TPS Values Fri, 17 September 2004 07:21 Go to previous messageGo to next message
Dale, the TPS is shot. Gives only two resistance readings. I tested it against my 100kw one which gave perfect readings but rotates in the opposite direction Sad.
I have ordered a new 20v one from Toyota.
Re: 20v TPS Values Fri, 17 September 2004 07:34 Go to previous message
10sec_rx7 wrote on Fri, 17 September 2004 16:53
ford ones just seem to be crap! my XF mate has had 3 or 4 brand new ones, and they just die really quickly.... they are sealed so it's not grit/water ingress... they just suck Wink
Previous Topic:Jaycar digital fuel adjuster
Next Topic:TA22 Inteior into RA23
Current Time: Fri Nov 20 20:52:01 UTC 2026
Total time taken to generate the page: 0.0054080486297607 seconds
