Toymods » Tech & Conversions » 20V Modifications - Cams
SecaSX
20V Modifications - Cams Wed, 15 September 2004 15:16 Go to next message
Hey Guys
Just looking to get some info on modifying my 20v.
If I want to go for bigger cams what is the largest size I can go for with the stock ECU? I was thinking 264 or 288 degree cams.
Would I need to get adjustable cam gears to dial in the cams?
If so will I loose the VVT function?
Looking for some cams which will give me some better performance and give me a nice rough/lumpy idle.
SecaSX
Re: 20V Modifications - Cams Fri, 17 September 2004 06:47 Go to previous messageGo to next message
Any one got any details.
All help would be appreciated.
Flogbag
Sydney (Campbelltown...!)
Re: 20V Modifications - Cams Fri, 17 September 2004 08:42 Go to previous messageGo to next message
if you get adjustable cam gears you cant run vvti...
goto the toda site they prolly have the best selection of cams for the 20v as trd only make one set which are 304 degrees
heard that if u go with higher lift ones you need to change valve springs only as 20v comes with underbucket shims
with a standard computer i dont think you would be able to go to big, so as cams are bout the same price for watever profile you want id buy big, get valve spring kit and aftermarket computer..
just my thoughts
sideshow
Re: 20V Modifications - Cams Fri, 17 September 2004 08:48 Go to previous message
if u go to big on the cams and yr engine runs and airflow meter
then yr idle will be up the shit
not as bad on map sensor but if duration is great u loose vacuum and airflow meter sends wrong signal to ecu
Previous Topic:thermostat inquiry
Next Topic:Tokico HTS
Current Time: Fri Oct 30 14:42:36 UTC 2026
Total time taken to generate the page: 0.26323485374451 seconds
