Toymods » Tech & Conversions » Cams for ST162
RWDboy
Cams for ST162 Thu, 16 September 2004 03:05 Go to next message
I'm guessing my best bet to get my cams (for my 1st Gen 3S-GE) cleaned up would be to send them to Wade Cams...question though...would they have a profile on hand for the 3S-GE cam that would make it a bit 'warmer' so to speak - I know, I know, I'll lose a bit of bottom end, and unless it's all matched up to intake manifold and ports etc etc then cam modifications are crap - but can anyone fault the original cam profile for 1st gen 3S-GEs? If there is a better profile or if anyone knows some resources about where I can work these things out could you let me know? What kind of measurements would I have to take to match up the cam with the rest of the engine? I know a few 'rules of thumb' but I'm not going to toy around with rules of thumb without some research or well-researched opinions on hand.
RWDboy
Re: Cams for ST162 Thu, 16 September 2004 03:08 Go to previous messageGo to next message
Oh, one thing - does the fact that the 1st Gen 3S-GE have uneven intake path lengths affect the performance variation across the cylinders or is it a negligible factor?
dar_sbb
Re: Cams for ST162 Thu, 16 September 2004 03:26 Go to previous messageGo to next message
i asked a lil while back for reginds on the stock cams, but they said cause of the efi (i suppose they meant ecu) they can only do one regind on them
RWDboy
Re: Cams for ST162 Thu, 16 September 2004 03:29 Go to previous messageGo to next message
Hmmm - sounds like a ghey excuse to me, can't see how EFI or ECU would affect their ability to be ground. Tighe Cams make a few cams for the ST162, maybe it's cheaper to get some new ones? Or is re-grinding relatively cheap? I suppose I should make some calls and find out myself ey Smile
dar_sbb
Re: Cams for ST162 Thu, 16 September 2004 03:39 Go to previous messageGo to next message
i think reginds are like 145 a shaft... i think...
the ecu is the biggest dix for camshaft mods
RWDboy
Re: Cams for ST162 Thu, 16 September 2004 04:13 Go to previous message
Well there's a certain point past which the ECU will no longer work efficiently with the cams selected (given it's desired A/F map) and the ignition timing....anyway...does anyone have answers to the other questions?
Cheers for the price on regrinds btw!
Previous Topic:TVIS
Next Topic:Bonnet pins legality
Current Time: Fri Nov 20 15:51:31 UTC 2026
Total time taken to generate the page: 0.0050837993621826 seconds
