Toymods » Tech & Conversions » 4AGZE TPS Calibration??? anyone know how to properly??
Alainve
Newcastle NSW
4AGZE TPS Calibration??? anyone know how to properly?? Thu, 16 September 2004 07:15 Go to next message
As above does anyone know the correct way to calibrate the TPS on a 4AGZE? since swapping over to 3SGE TB i havent calibrated it properly yet. theres no major issue but light throttle and on/of throttle can be a bit jerky at times. any help? Smile
EVOSTi
cambo
      no
Re: 4AGZE TPS Calibration??? anyone know how to properly?? Thu, 16 September 2004 08:10 Go to previous messageGo to next message
is it a variable signal TPS?
Alainve
Newcastle NSW
Re: 4AGZE TPS Calibration??? anyone know how to properly?? Fri, 17 September 2004 06:55 Go to previous messageGo to next message
its a 4 wire variable with earth switch same as 3sge and most late model toyotas
Re: 4AGZE TPS Calibration??? anyone know how to properly?? Fri, 17 September 2004 07:48 Go to previous messageGo to next message
Completely close the throttle, unplug the TPS, and measure the resistance that goes from Short Circuit to Open circuit as soon as the throttle is touched.
Then move the throttle minutely.
Adjust the TPS until it changes from SC to OC.
Let go of the throttle, making sure it goes back to SC.
Tighten TPS
drift86levin
brisvegas
Re: 4AGZE TPS Calibration??? anyone know how to properly?? Fri, 17 September 2004 09:50 Go to previous messageGo to next message
i know it sounds a bit stupid and easy..but all i did was loosen it..move it a tad..go for a drive..etc..etc..trial and error..i have the same setup on my ZE..it's perfect now..
sideshow
Re: 4AGZE TPS Calibration??? anyone know how to properly?? Fri, 17 September 2004 13:42 Go to previous message
between the red wire and the brown wire u should have about 0.4
volts with ignition on
u should also have 0 volts between the blue and the brown
Previous Topic:ST162 help
Next Topic:high/low beam? Lets burn a globe out good!!! :D
Current Time: Sat Oct 31 16:22:59 UTC 2026
Total time taken to generate the page: 0.066973209381104 seconds
