Toymods » Tech & Conversions » Gen2 to Gen 3 Turbos
BLK1GGTE
South Eastern Subs
Gen2 to Gen 3 Turbos Thu, 16 September 2004 08:25 Go to next message
Can you fit the Gen3 Turbos on a Gen 2 engine. If yes whats involved in doing so. I know they are diffrent on the exaust/dump pipe side of it? Does anyone know if these are actually better turbos then Gen2?
Ribbo
Northern Beaches
Re: Gen2 to Gen 3 Turbos Thu, 16 September 2004 08:37 Go to previous messageGo to next message
they will fit on with no problems
Fattony
Re: Gen2 to Gen 3 Turbos Thu, 16 September 2004 08:42 Go to previous messageGo to next message
Do a search, there is a thread which lists the differences, and YES some are relivent to you doing such a change.
ddeane
PNG
Re: Gen2 to Gen 3 Turbos Fri, 17 September 2004 00:55 Go to previous messageGo to next message
Gidday
NO THEY WILL NOT FIT as a direct replacement! The gen 3 turbos have a larger outlet on the compressor cover - 'spose this means they have a larger wheel and can flow more. You will need the outlet pipes from a gen 3 engine as the bolt up is very different. Whether they will give improved performance I do not known as the exhaust manifold for a gen 3 is also different from a gen2 (looks like it has less obstrustion). I also understand that from the factory a gen2 runs 9psi and a gen3 11psi.
Craig
Fattony
Re: Gen2 to Gen 3 Turbos Fri, 17 September 2004 08:24 Go to previous messageGo to next message
We have swapped a twin to single turbo bridging manifold which was built for a gen 1 onto a gen 3 and it went on without any problems. So i think you shall find that they will bolt to the zorst manifold no probs.
gold28
Madrid - Spain
Re: Gen2 to Gen 3 Turbos Wed, 22 September 2004 11:55 Go to previous messageGo to next message
I did a write up on the differences some time back, see this link
Essentially the exhaust side is all the same and the inlet is different. They will bolt up so long as you get the cast alloy pipes on the AFM side of the compressor. All the coolant and oil lines are the same, so no worries there either.
The gen3 turbos seem a bit wider, so if your rear turbo is close to your steering box or master cylinder it may cause issues. i didn't notice this until I bolted them in and couldn't get a heat shield on.
mycress
Re: Gen2 to Gen 3 Turbos Wed, 22 September 2004 18:06 Go to previous messageGo to next message
Now u mentioned about the rear turbo being too close to the steering box, mine started to leak now.... Did you get any solution for this mate???
cheers.....
gold28
Madrid - Spain
Re: Gen2 to Gen 3 Turbos Thu, 23 September 2004 08:22 Go to previous message
Fortunately mine had enough clearance to squeeze in a shield I made from tin plate. If yours is closer then best of luck to ya.
Previous Topic:i need starlet engine info..
Next Topic:gearbox weights
Current Time: Sun Oct 25 09:01:48 UTC 2026
Total time taken to generate the page: 0.024698972702026 seconds
