Toymods » Tech & Conversions » 3S-GTE pistons to 3S-FE??????
PSIapollo
innisfail
3S-GTE pistons to 3S-FE?????? Thu, 16 September 2004 12:05 Go to next message
Does anyone know if u can put 3S-GTE pistons in a 3S-FE motor?
real curious, if i can i'll get some for my car instead of getting a decompression plate made up to bring my compression down!
RWDboy
Re: 3S-GTE pistons to 3S-FE?????? Thu, 16 September 2004 12:43 Go to previous messageGo to next message
Why do you need to bring the compression down???
da_horse
Melbourne Australia
Re: 3S-GTE pistons to 3S-FE?????? Thu, 16 September 2004 13:50 Go to previous messageGo to next message
off the top of my head, the internals from the 3sgte and 3sfe are all different. same 3s block, different heads (ge /fe ) and i think different internals too. there was a post similar to this on ToyotaNation once.
the only reason i can think of that would require him to lower his compression is if he was planning a turbo conversion.
i'll try to find some clarification, but try ringing a toyota spare parts place and see what they say...
Huy
Re: 3S-GTE pistons to 3S-FE?????? Thu, 16 September 2004 23:30 Go to previous messageGo to next message
I suspect you'll have problems with valve-to-piston clearance if you tried such a swap.
RWDboy
Re: 3S-GTE pistons to 3S-FE?????? Fri, 17 September 2004 04:47 Go to previous messageGo to next message
Yeah - the combustion chamber shape of the FE heads is much *much* flatter and shallower than the GE/GTE heads, so I doubt you'll lower the compression by much, if at all - you may even raise it with the GE/GTE pistons. The GE/GTE pistons have a crown shape, whereas the FE pistons are all dish-type. The gudgeon pin diameter should be the same, so they will fit on, but I doubt it'll have the effect that you want.
PSIapollo
innisfail
Re: 3S-GTE pistons to 3S-FE?????? Fri, 17 September 2004 08:54 Go to previous messageGo to next message
Thats cool, decompression plate will be way to go then,
Yeah i'm planning to turbo it, nothing major just ct26 on standard 3S-GTE manifold, once i'm finished i'll sell it and do something else, just wanna say i have a turbo apollo!
RWDboy
Re: 3S-GTE pistons to 3S-FE?????? Sat, 18 September 2004 00:38 Go to previous messageGo to next message
You may not need to decompress it that much you could just grab a copper head gasket that is 2mm thick or something...if you are using standard FE intake (ie injectors/ECU etc) then you won't be able to run much more than about 6psi of boost anyway.
PSIapollo
innisfail
Re: 3S-GTE pistons to 3S-FE?????? Sat, 18 September 2004 02:39 Go to previous messageGo to next message
yeah thats all i was thinking of getting was a 2mm or even a 1.5mm gasket, but if i max out the injectos could i run more boost with that standard computer?
RWDboy
Re: 3S-GTE pistons to 3S-FE?????? Sat, 18 September 2004 03:35 Go to previous messageGo to next message
Well, it's likely your standard computer will be more of an issue...although the FE injectors are kinda weak - I dunno if you can put the GE/GTE injectors in the fuel rail. The standard ECU won't run rich enough - I know there *should* be an idle mixture adjustment screw (dunno about where it is on your car tho) which you can use to adjust the fuel ratio minorly - but really I reckon you'll be lucky to get more than 6psi...you running any intercooler at all?
PSIapollo
innisfail
Re: 3S-GTE pistons to 3S-FE?????? Sat, 18 September 2004 04:26 Go to previous messageGo to next message
YeaH I'll be running a intercooler, maybr i can get my injectors hi-flowed and get the computer unichiped? maybe that'll be alright to run 12psi? I'm only aiming for 150-180hp at the wheels! nothing major! but we''l see what the mechanic reakons
RWDboy
Re: 3S-GTE pistons to 3S-FE?????? Sat, 18 September 2004 14:50 Go to previous messageGo to next message
Sounds like you are talking about a bit o' money here Razz Good luck with this
PSIapollo
innisfail
Re: 3S-GTE pistons to 3S-FE?????? Sun, 19 September 2004 00:46 Go to previous message
Nah, it wont cost that much hey, it's all pretty basic, wait till i get my supra! then we'll talk a lot of money! haha
Previous Topic:DIY Alternator reco?
Next Topic:Something I should already know.
Current Time: Sun Oct 18 05:21:24 UTC 2026
Total time taken to generate the page: 0.018013000488281 seconds
