Toymods » Tech & Conversions » Excessive Engine Bay Temps
CamZH
Toodyay, WA
Excessive Engine Bay Temps Thu, 16 September 2004 14:39 Go to next message
Hey guys...
I've got a cooling issue with my ute...
Its got a set of extractors that basically wrap around the starter...
i've noticed when doing a bit of circle work that the heat of the extractors is devastating !!
Just last week it melted my clutch cable that is a good 200mm away !
I'm thinking about getting some heat wrap for the extractors as a tempory fix until i change the head which will need new pipes...
Will this stuff stand upto the abuse of this kind of heat ? I get the impression its more for normal driving, not dyno runs and burnouts....
I know the HPC coating is the way to go, but my extractors are pretty crap and will be replaced within 12 months...
thanks,
Cam
IRA11Y
Club Member
Re: Excessive Engine Bay Temps Fri, 17 September 2004 11:09 Go to previous messageGo to next message
My experience with wrap is that its a PITA, often comes unraveled after about 6 months, dosent like getting wet at all, and is not nearly as good as HPC.. commit to the new pipes and hpc dont waste time effort and money on wrap.
mx83toy
Re: Excessive Engine Bay Temps Fri, 17 September 2004 15:34 Go to previous messageGo to next message
SSV have a lil scoop about 10cm x 120cm and about 2cm tall it sits just infront of your wiper water jets and the whole faces the windscreen... it creates a negative presure at the opening and extracts heat sells for 80 bucks... i'm looking at putting one on the cressi before i paint the lil bitch Smile
Re: Excessive Engine Bay Temps Sat, 18 September 2004 03:14 Go to previous messageGo to next message
Is it normal for your extractors to be getting hot enough to melt something 20cm away? Maybe your timing is too retarded (for example) which is creating excessive exhaust temperatures...
CamZH
Toodyay, WA
Re: Excessive Engine Bay Temps Sat, 18 September 2004 12:05 Go to previous messageGo to next message
I think a scoop would be useless, as you need to be moving to create air flow !
Timing: Not to sure, i'll play with it after i put in the HEI unit...
And no, i dont think it is normal to melt things 20cm away from your extractors Smile
also forgot to mention, new extracors will be coming with a new head... or is that the other way around ??
maybe a heat shield is my best defence against heat damage ??
At least it'd protect the starter !
Cam
Re: Excessive Engine Bay Temps Sat, 18 September 2004 12:14 Go to previous messageGo to next message
Yes, a strategically-placed heat shield can work wonders. It's worth a try anyway. Smile
CamZH
Toodyay, WA
Re: Excessive Engine Bay Temps Sat, 18 September 2004 12:43 Go to previous messageGo to next message
Well i've got a few sheets of corogated iron around !
might just do the trick Smile
Cam
CLG
Perth, Western Australia
Re: Excessive Engine Bay Temps Sat, 18 September 2004 16:46 Go to previous messageGo to next message
You just leave my baby alone Lucas!
I've got some thermal wrap left in the shed somewhere, if I find it, I'll through it your way!
coronamark2
Re: Excessive Engine Bay Temps Sun, 19 September 2004 14:16 Go to previous messageGo to next message
i've got some heat wrap around the last three pipes on the 4m it works well you can touch the pipes not long after thrashing it, where as i touched the other 3 and burnt fuck out of my fingers
i cooked the seals in the steering box it cost me $500 to get it recond Shocked
maybe you can wrap some of the heat stuff around the starter?
BLK1GGTE
South Eastern Subs
Re: Excessive Engine Bay Temps Sun, 19 September 2004 14:43 Go to previous message
I had the same problem in my Hq Monaro in the burnout comps it would cook the starter motor wiring. Send your extractors to Jethot or HPC. That solved the problem for me...I also made some heat shield out of aluminium and bolted it around the starter.
Previous Topic:springs/shocks matching
Next Topic:Bizzare 7MGTE balancer 'problem'
Current Time: Fri Nov 20 14:50:25 UTC 2026
Total time taken to generate the page: 0.012209892272949 seconds
