Toymods » Tech & Conversions » cam sensor seal
zecscott
adelaide
cam sensor seal Thu, 16 September 2004 22:52 Go to next message
the seal in my cam sensor is stuffed, hence a small oil leak. is it hard to change this? ie the sensor doesn't have to be re-aligned when put back on? (4agze)
[Updated on: Thu, 16 September 2004 22:52]
Rod83
Re: cam sensor seal Fri, 17 September 2004 00:59 Go to previous message
Not hard to change at all if you're talking about the oring which seals the sensor to the head.
You will have to realign it though, but as long as you're careful you won't have any trouble. Might be a good idea to have a timing light handy to check if you're timing is right when you put it back in.
Previous Topic:what clutch??
Next Topic:ke20 brakes
Current Time: Fri Nov 20 17:54:09 UTC 2026
Total time taken to generate the page: 0.0049560070037842 seconds
