Toymods » Tech & Conversions » MA61 rear axle bearing
RA28
MA61 rear axle bearing Fri, 17 September 2004 01:40 Go to next message
Can a normal person change a rear axle bearing on a MA61 or do they need to be pressed on or off or something?
Tim.
bbaacchhyy
Re: MA61 rear axle bearing Fri, 17 September 2004 02:17 Go to previous messageGo to next message
If you are talking about the inner and outer tapered bearings on the stub axle, it depends.
I took mine out (as part of the 5 stud conversion) and bought the bearings, but took it to a suspension shop (with a copy of the relevant pages of the TRSM) for them to reassemble it, as it is a bit involved. The arms were out of the car of course.
It is a similar setup to a Crumpledore IRS setup. They charged me $45/side to reassemble.
If need be, I have the bearing numbers here with me.
What is wrong with your bearings ? Pulling mine apart showed absolutely no wear whatsover, and the grease was clean as a whistle !!
Michael B
RA28
Re: MA61 rear axle bearing Fri, 17 September 2004 06:25 Go to previous message
No idea what's wrong, I'm a celica guy Wink
The car is a mates, tried to get a pink slip and the guy said left rear axel bearing/s among other things. I'm going up to see him this weekend and I'll have a look and see what's wrong.
Tim
Previous Topic:1NZ-FE & 2NZ-FE Lifter Sizes and Toyota PN#
Next Topic:4AG Cam covers - can i swap em ? - Big port - small port.
Current Time: Fri Nov 20 19:24:09 UTC 2026
Total time taken to generate the page: 0.010221004486084 seconds
