Toymods » Tech & Conversions » TruTrac Diff noisy?
ZZT231
melbourne.vic.au
TruTrac Diff noisy? Fri, 17 September 2004 03:04 Go to next message
Hey All,
After installing the Diff, does the diff make a lot of noise ie whining?
Cheers.
bbaacchhyy
Re: TruTrac Diff noisy? Fri, 17 September 2004 03:07 Go to previous messageGo to next message
If not installed properly, yes.
ZZT231
melbourne.vic.au
Re: TruTrac Diff noisy? Fri, 17 September 2004 03:08 Go to previous messageGo to next message
Damn Sad
bbaacchhyy
Re: TruTrac Diff noisy? Fri, 17 September 2004 03:13 Go to previous messageGo to next message
It may be that the crownwheel is not set up properly with the pinion.
Who did it ?
If it wasn't noisy before, I'd take it back and get them to check it out.
Any more details of who/what/where/why etc ?
Re: TruTrac Diff noisy? Fri, 17 September 2004 03:16 Go to previous messageGo to next message
I'm with Michael here. It should be quiet.
It maybe that the crown wheel and pinion were not setup correctly or there may be a suspect bearing.
When does the whining occur? On acceleration, deceleration or constant load? I'm assuming you put the correct oil in it?
Re: TruTrac Diff noisy? Fri, 17 September 2004 04:27 Go to previous messageGo to next message
What they said; my diff is whisper-quiet. If (for example) the pinion preload hasn't been set properly, it will make a hell of a racket - but that's nothing to do with the TrueTrac itself.
ZZT231
melbourne.vic.au
Re: TruTrac Diff noisy? Fri, 17 September 2004 08:21 Go to previous messageGo to next message
bbaacchhyy wrote on Fri, 17 September 2004 13:13
Who did it ?
Well I have only driven 10,000kms since the last engine rebuild (in June), and I *think* I just did another Head gasket Mad as the radiator is bubbling with air with the cap removed Mad Mad Mad
Earlier in the year I when I got the panel work done to the car, I got the diff put in as my panel beater organised it for me Smile So I'll call him when he gets home to get it fixed...
Would the whining damage the diff pinion or crownwheel at all?
Cheers...
Danish
Re: TruTrac Diff noisy? Mon, 08 November 2004 06:44 Go to previous messageGo to next message
On a similar note,
I have a 4 pinnion diff/carrier and a 2 pinnion diff/carrier, which carrier is better to use with the Torsen LSD I am putting in? Does it have any affect at all?
I currently have swapped my 4 pinnion carrier for a 2 pinnion one. This is so I can still drive my car, take the carrier and LSD centre to get put in, then swap the carrier on my car when I get home.
Re: TruTrac Diff noisy? Mon, 08 November 2004 06:46 Go to previous messageGo to next message
The 2-pinion/4-pinion part (ie the diff centre) gets replaced entirely by the TrueTrac centre, so it doesn't make any difference.
Re: TruTrac Diff noisy? Mon, 08 November 2004 06:50 Go to previous messageGo to next message
Is the Truetrac 2 or 4 pinion, of does that have no bearing in this matter?
Re: TruTrac Diff noisy? Mon, 08 November 2004 08:16 Go to previous message
Nup, helical LSD's don't have pinion gears.
Previous Topic:AE86 Handbrake Adjustment (SOLVED)
Next Topic:18rgeu timing diagram
Current Time: Sat Oct 24 09:58:36 UTC 2026
Total time taken to generate the page: 0.006173849105835 seconds
