Toymods » Tech & Conversions » Urgent Help Needed - No Injector Pulse
ra23celica
Urgent Help Needed - No Injector Pulse Fri, 17 September 2004 04:43 Go to next message
I look like being car-less for the weekend unless I sort this one out.
My 1G-GZE has no injector pulse.
What are the likely causes and how can I test and eliminate them / find the culprit ?
Thanks,
Mitch.
TA22-3SGTE
MACKAY
Re: Urgent Help Needed - No Injector Pulse Fri, 17 September 2004 13:24 Go to previous messageGo to next message
If there is no injector pulse there is probobly no spark either which I would say there is no input signal from the CAS .
Trevor
sideshow
Re: Urgent Help Needed - No Injector Pulse Fri, 17 September 2004 13:37 Go to previous messageGo to next message
could be nafew things
check for power at injectors
both wires will show 12 volts due to feedback from other injectors
u can have spark but no injection because toyota ecus stop injection if engine doesnt start after afew turns to stop flooding
best thing to try is spray aerostart in intake and if it starts its fuel related then check fuel lines pump pressure etc
remove return line and crank engine see if u have good fuel comin back
sprinterman68
penrith
Re: Urgent Help Needed - No Injector Pulse Sat, 18 September 2004 06:01 Go to previous messageGo to next message
check that the ecu is getting a cranking sense.the ecu needs to know that yr trying to start the engine.
sideshow
Re: Urgent Help Needed - No Injector Pulse Sat, 18 September 2004 07:37 Go to previous message
the crank sig doesnt matter
its just for enrichment
heres how toyota ecus work
if uhave dizzy signal
then u get spark and fuel
if u get spark and not fuel it can sometimes mean that the ecu has turned the injectors off incase u flood the engine
easiest way to check is
start it with aero start
if it runs then its fuel related
which means bad poower to injectors or no fuel pressure or flow
or bad earth for the injector drivers inside the ecu
its very easy to check
Previous Topic:3SGE + 3SGTE Intake manifold
Next Topic:holley carby???
Current Time: Sat Oct 10 11:18:45 UTC 2026
Total time taken to generate the page: 0.042301177978516 seconds
