Toymods » Tech & Conversions » turbo timer wiring
dwango
turbo timer wiring Fri, 17 September 2004 06:17 Go to next message
I have purchased a secong hand Razo turbo timer. I need some idea how to hook it up.
I'll describe it.
1 very short yellow wire coming from back with a jet plug on the end, I think the guy i bought it from suggested this went to the park brake. How do I connect in to the park brake for a start?
Then a 40cm cable to a 3 pin male plug with a red a blue and a green inside. Then extending 10 cms past the plug is a red and a black wire.
Re: turbo timer wiring Fri, 17 September 2004 08:32 Go to previous messageGo to next message
If you cant work it out, pop around here on the weekend and i'll have a looksee.
sideshow
Re: turbo timer wiring Fri, 17 September 2004 09:08 Go to previous messageGo to next message
red is battery
green is ignition
blue is accessories or 2nd ignition
black is earth
if timer turns on but doesnt count down
then the yellow might be for the handbrake
just splice it into the wire that comes from handbrake switch
or just earth it to ground connect to black wire
this way u dont need handbrake up for timer to work
there is no warranty on this advice Smile
wire at yr own risk
Guest
Re: turbo timer wiring Fri, 17 September 2004 09:10 Go to previous messageGo to next message
Try this site for some info:
http://www.supras.nl/view.php?page=modsTurboTimer. htm
JC.
dwango
Re: turbo timer wiring Fri, 17 September 2004 10:11 Go to previous message
Cool, Good info. Also I found this link after a bit of searching. It says the black is handbrake, but that is 3 to 1 against him. I rekkon the yellow too. And yep a guy at jap imports told me the yellow is handbrake.
http://forums.toymods.org.au/index.php?th=972& t=msg
I will have to get money / buy jet plugs n connectors before i actually do anything.
Thanks Cool1 I'll take you up on that offer if i get stuck.
Previous Topic:HELP!!! Sony Changer.
Next Topic:boost drop
Current Time: Fri Oct 30 20:19:25 UTC 2026
Total time taken to generate the page: 0.0073831081390381 seconds
