Toymods » Tech & Conversions » 2TG throttle body and air flow meter
filthman
Heathmont, Melbourne, Vic
2TG throttle body and air flow meter Fri, 17 September 2004 07:53 Go to next message
I have a 2TG with some of the EFI gear for it. Does anyone know of an airflow meter that will work with the standard computer?
The 2TG items are a bit hard to find. I was looking at using an early 4AGE one with the 4AGE computer at this stage.
Is there a larger throttle body that fits on to the 2TG plenum chamber without a custom adaptor?
If anyone happens to have the standard 2TG ECU, airflow meter, and loom, please let me know.
filthman@rabbit.com.au
people100
Rocklea qld
Re: 2TG throttle body and air flow meter Sat, 18 September 2004 08:17 Go to previous messageGo to next message
talk to lilcrash. I think he still has his original ecu
T APLUS 22
Re: 2TG throttle body and air flow meter Sun, 19 September 2004 23:54 Go to previous messageGo to next message
I have a bog stock 2TGEU. with original loom, ecu however I suspect my Air Flow Meter is not the original. But a much larger item. Possibly from another toyota. I come to this conclusion after seeing another 2tgeu with smaller AFM. What did u need to know?
filthman
Re: 2TG throttle body and air flow meter Mon, 20 September 2004 09:09 Go to previous messageGo to next message
I know both the trottle body and airflow meter are quite small, so I'm just trying to find out if there is another larger airflow meter that will 'plug in' to the factory ecu and work properly or will it effect the air/fuel ratios too much?
Are you running the standard trottle body on yours?
Re: 2TG throttle body and air flow meter Mon, 20 September 2004 12:34 Go to previous message
I've heard that a Camry air flow meter will work alright with a 2TG, and maybe even a 22RE one - note that I said 'heard' not 'tried'!
Also, I gather that swapping the throttle on an otherwise stock motor will do little for you...
Previous Topic:Flares
Next Topic:AE111 shift assembly into an AE92
Current Time: Thu Nov 19 15:09:35 UTC 2026
Total time taken to generate the page: 0.0057308673858643 seconds
