Toymods » Tech & Conversions » Stock rim size for 74 TA22 ???
manipulate
Stock rim size for 74 TA22 ??? Tue, 24 September 2002 05:35 Go to next message
Hey all
anyone know what the stock rim size is for a 74 ta22. Cause im trying to figure out whats the widest i can go legally.
Apparently u can only go 2" wider than stock right ??
Ta
Mani
Very Happy
dorikin
NE Melbourne
Re: Stock rim size for 74 TA22 ??? Tue, 24 September 2002 06:18 Go to previous messageGo to next message
1974 TA22 has 13x4.5 inch rims...
i'm not 100% sure about the laws in sydney, but from memory if the car is pre 1973 then you can go to 7 inch wide. after 1973 then the law specifies only 1 inch wider than standard. although i'm not completely sure of this, look it up, it's not difficult to find on the net...
manipulate
Re: Stock rim size for 74 TA22 ??? Tue, 24 September 2002 09:01 Go to previous messageGo to next message
Hmmm ta... but cant find
any one else ??
4SFED
Melbourne, VIC
Re: Stock rim size for 74 TA22 ??? Thu, 26 September 2002 04:07 Go to previous messageGo to next message
I am running 17x7's front and back... dunno how "legal" it is tho... Smile
manipulate
Re: Stock rim size for 74 TA22 ??? Thu, 26 September 2002 06:02 Go to previous messageGo to next message
That 13B turbo isnt too legal now is it ??? Very Happy
4SFED
Melbourne, VIC
Re: Stock rim size for 74 TA22 ??? Fri, 27 September 2002 00:14 Go to previous messageGo to next message
manipulate wrote on Thu, 26 September 2002 16:02
aaahhhh... errr... next question! Smile
i dont think i have too much left on the car that is "technically" legal.
13BT = no
BIG turbo = no
Motec = no
17" wheels = no
rollcage = no
harnesses = no
exhaust = no
pollution gear = no
ride height = no
looks like i had better makes friends with a good cop ASAP! Smile
hehehe
manipulate
Re: Stock rim size for 74 TA22 ??? Wed, 02 October 2002 06:13 Go to previous messageGo to next message
bajeebus......good luck with that ey
K well i found out what it is ...13" X 4.5"J (dunno what the J is)
next question .....i need to find out the stock rolling circumference.....ive found these specs of the stock tires
but be f**ked if i can understand what they mean:
6.45S 13, 4PR
165SR 13
What is that in normal tyre terms someone
Ta
Mani
[Updated on: Wed, 02 October 2002 06:25]
dorikin
NE Melbourne
Re: Stock rim size for 74 TA22 ??? Wed, 02 October 2002 06:55 Go to previous messageGo to next message
the "J" means it's a safety rim. that means that the tyre bead is held in place with an extra bead moulded into the rim so that the bead "shouldn't" come detached in case of overload, deflation, etc.
as for the rolling circumfrance, i can't help you out with that right now. there are plenty of online calculators that can work this out for you, including what tyre sizes will retain your correct spedo calibration. i have lost the link right now, but somone else may know of one.
manipulate
Re: Stock rim size for 74 TA22 ??? Wed, 02 October 2002 07:11 Go to previous messageGo to next message
YEP ive got the calculator thingo !!!!!!
But like i said i found those above sizes:
6.45S 13, 4PR
165SR 13
But i need them in normal tyre terms to calculate it
i can see it says 13's.....and they are 165's.....but i need that middle number
Ta
Mani
Brown Hornet
Re: Stock rim size for 74 TA22 ??? Wed, 02 October 2002 12:56 Go to previous messageGo to next message
Here are some rolling diameters i've worked out for you guys.if you'se have microsoft ofice i have a database that you'll love.just email or msn me and i'll send it to ya's no probs.
13/75/165=577.7mm/22.44 inch
13/80/165=594.2mm/23.93 inch
ENJOY! Evil or Very Mad
thetoyman75
Club President
Re: Stock rim size for 74 TA22 ??? Thu, 03 October 2002 04:50 Go to previous messageGo to next message
Manipulate,
The 165 SR 13" is a 82 profile tire ! Any Decent Tire place should be able to provide you with Rolling Diametre figures.
The Rolling Diametre of the Dunlop 165 SR 13 is 596mm You should be able to get a photocopy of that from any of the older tyre places for your engineer.
In NSW the legislation on wheels and tires is pretty tight you need to refer to "Vehicle Standards Information Sheet No. 9" You want to get yourself a copy of it to make sure you don't waste your dollars.
Rims width depends on the RTA recorded weight of your vehicle as well as the age ofthe car. PRE Jan 1973 can fit a 7" rear rim (For a celica anyway)
After Jan 73 you are limited to a 6" wide rim (1 1/2 over standard) if you use the factory diff and axels. The legislation is based on the axel used not on the car its in. YOu are allowed to owner certify a 1" increase but to get the extra 1/2 an inch it needs to be engineer approved.
Overall Diameter limit is 15mm variance. (above or below)
I know your probably think F*#k it who will know. You hit something expensive you insurance company will use any excuse not to pay ! Sad
As a point of refernce the RA23 has a 5" factory rim Smile My Celica has a RA23 diff so I can actually run a 6 1/2 Inch wide rim if I want Wink (Make sure you keep it in track tho. Track can only vary 25mm from memory)
Hope that helps Smile
manipulate
Re: Stock rim size for 74 TA22 ??? Thu, 03 October 2002 05:21 Go to previous messageGo to next message
Thanx Heaps rod thats very informative...i'll go get that information sheet from the RTA i assume
If anyone cares the diameter of a stock ta22 wheel is 600.8mm
So that means the wheels im getting that are 7" wide are illegal unless i change my diff....sweet
and no im not gonna say F**K it....i dont wanna get hassled plus rules are made for a reason....and shane dont say to be broken
heres the link to that Info Sheet Rod was talking about if anyone cares http://www.rta.nsw.gov.au/registration/vsi09.pdf
Thanx again Rod
Ta
Mani
[Updated on: Thu, 03 October 2002 05:25]
PIG KIL
AdElAiDe
Re: Stock rim size for 74 TA22 ??? Thu, 03 October 2002 11:07 Go to previous message
i have 14 x 8's all round on my ta22 and it isn't legal. went to the police station and they said widest i could have is 6 inches wide
Previous Topic:3 questions on the 1jz
Next Topic:Corolla Seats
Current Time: Sun Nov 1 23:01:24 UTC 2026
Total time taken to generate the page: 0.0057001113891602 seconds
