Toymods » Tech & Conversions » trying to stop
RA28
trying to stop Thu, 23 May 2002 13:40 Go to next message
I have a 77RA28 and have a set of discs and calipers off a RA60. These are a bit bigger I believe and are vented. The two hubs have different mountng points though so I will have to make an adaption plate to fit them.
Is this safe to do? can I make a plate out of a chunck of plate or will it flex too much?? Also, is it worth while?? Will these discs be much better than stock or should I save my time and just get something better later?
I would like to fit an 18rg or a 1ggte one day when I am finished with the rest of crap I am doing with it so I might as well fit something that will be good enough for that.
If it is OK, can anyone suggest how thick the plate would have to be to eliminate flex??
Also, I have the front and rear swaybars of the same celica, will these fit?
TOY77
Re: trying to stop Fri, 24 May 2002 07:06 Go to previous message
Mate,
Don't muck around.. go for the hilux calipers, corona struts and pugeot discs.
The conversion is outlined in the tech section of this website.
I have this set up in my RA28 and it is awesome and if i had a stock car i would still use these!
By the way i have a 1ggte, and you appreciate brakes this good, as did the engineer.
In total it cost me bout $600
Stew
Previous Topic:Spark Plug Question
Next Topic:Compliance
Current Time: Sun Nov 22 18:31:16 UTC 2026
Total time taken to generate the page: 0.0039689540863037 seconds
