Toymods » Tech & Conversions » A4-C To A4-GE
killerx
The Hills
icon4.gif  A4-C To A4-GE Sun, 19 September 2004 06:58 Go to next message
hey ppl
i'm considering buying an aust-spec 86 and want 2 know that if at some later point if i wish 2 put a A4-ge and ECU from jap in (RWD ver not the FWD ver and not GZE)what addition modifications would have 2 b made to the 2 accomidate the change
eg. would the i need 2 modify the fuel tank and management system as well as piping due to the diffrences betwwen the JDM and AUST '86s (i read this in a post somewhere but it was 4 GZE but is it 4 GE 2). and i know i'll probably have 2 change the clutch as well b4 any1 points this out.
i've been lookin through the forum and and no-1 has given a definative answer to this question.
wilbo666
Re: A4-C To A4-GE Sun, 19 September 2004 07:12 Go to previous messageGo to next message
4a-c to 4age, not a4c or a4ge lol
as the 4ac is carby and not efi, you will need to do something about the fuel system if you go EFI, surge tank / high pressure efi pump spring to mind?, although I've never had to research it myself (do a search....).
you honestly can't have searched that hard if you can't find info Confused AE86's get talked about HEAPS on this (and other forums, google perhaps?)
Callifo
Gawler, SA
Re: A4-C To A4-GE Sun, 19 September 2004 07:23 Go to previous messageGo to next message
Yeh it would have definately been covered.
Main points are though exhaust, fuel system and clutch lines.
ae86drift
sydney.au
Re: A4-C To A4-GE Sun, 19 September 2004 07:28 Go to previous messageGo to next message
killerx wrote on Sun, 19 September 2004 16:58
hey ppl
from ac to age is
engine/ecu ect.
clutch
exhaust
t50 gearbox bellhousing
fuel pump/bracketing/surge
ae95
Re: A4-C To A4-GE Sun, 19 September 2004 17:41 Go to previous messageGo to next message
Callifo wrote on Sun, 19 September 2004 15:23
what do u have to do to the clutch line?
Callifo
Gawler, SA
Re: A4-C To A4-GE Sun, 19 September 2004 23:06 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=28006&rid=3270&S=9e0aacd5a580796f062860d 96db5d22c&pl_view=&start=0#msg_243199
killerx
The Hills
Re: A4-C To A4-GE Mon, 20 September 2004 00:21 Go to previous messageGo to next message
Yeh wilbo i did do a search b4 and there was 1 that talked about havin 2 switch from carbi 2 EFI but that was 4 a 4GZE not a 4GE
what type of exhaust upgrade would be need, would the path of the exhaust piping on the undercarriage of the car need to change or is it just an increase/decrease in size.
AE86slut
Baulko Hillo
Re: A4-C To A4-GE Mon, 20 September 2004 01:54 Go to previous messageGo to next message
Your extractors will be on the opposite side to the 4AC. And yes, you will definately want to increase the size!
dcleyne
Re: A4-C To A4-GE Mon, 20 September 2004 04:02 Go to previous messageGo to next message
Quote:
from ac to age is
engine/ecu ect.
clutch
exhaust
That's interesting. So you're saying the bellhousing pattern is different from the 4A-C to the 4A-GE?
I thought that the 'A' series bellhousing for the later T50 would fit all A series blocks. If not, which bellhousing should I be looking for?
I realise that there are a couple of variations of the T50 box but that in the Oz-Spec it should be the later box right?
drift86levin
brisvegas
Re: A4-C To A4-GE Mon, 20 September 2004 04:18 Go to previous messageGo to next message
it's not the bellhouseing itself..its the clutch slave cylider..it will be sitting about 4 inches away from your extractors..(not cool) just sheild it and you will be fine..run down to a wrecker and grab some exhasut shielding off a FWD celica 88-94 have shit loads on them..also TR 4cyl Magnas..as long as the bellhousing from the T-50 was off a 4AC..no dramas..
[Updated on: Mon, 20 September 2004 04:19]
AE86slut
Baulko Hillo
Re: A4-C To A4-GE Mon, 20 September 2004 04:21 Go to previous messageGo to next message
Bah.... you don't need to do anything except get a longer clutch line made up so it can run up and over your exhaust with a bit of distance from the pipe.
AE86slut
Baulko Hillo
Re: A4-C To A4-GE Mon, 20 September 2004 04:26 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&g oto=332960&rid=5429&S=502f307f15d203389489 c0de945156b5
dcleyne
Re: A4-C To A4-GE Mon, 20 September 2004 04:29 Go to previous messageGo to next message
Ahh, ok. My TA22 with the 2T/T50 runs the slave on the right hand side. I was thinking that I'd leave it on the RHS when I put the 4A-GE in. I was fairly sure that there was a mounting point for it on the right hand side of the bellhousing but I'm worried now so I'll check it when I get home. It happens that I have a T50 with bellhousing that came off a 4A-GE but it has none of the clutch bits with it because the motor had an auto box installed behind it and the guy I bought it off couldn't find the bits.
I was assuming that the existing slave line in the TA22 would still fit the slave cylinder from the later box/bellhousing. Again, I'll have to get off my behind and find out...
Cheers all,
Dan
ae95
Re: A4-C To A4-GE Mon, 20 September 2004 04:33 Go to previous messageGo to next message
the stock bellhousing will bolt up
but the clutch line will be right next to exhaust
you could just get a jdm bellhousing and get lines made up
drift86levin
brisvegas
Re: A4-C To A4-GE Mon, 20 September 2004 04:53 Go to previous messageGo to next message
ae95 wrote on Mon, 20 September 2004 14:33
they arn't that common to come across..
ae95
Re: A4-C To A4-GE Mon, 20 September 2004 04:56 Go to previous messageGo to next message
yerp agreed
EDIT
i think theres one for sale atm
[Updated on: Mon, 20 September 2004 04:56]
FKN16V
NSW, East Coast
Re: A4-C To A4-GE Mon, 20 September 2004 08:38 Go to previous messageGo to next message
Just use the 4ac gearbox, yes the clutch line will be close to the exhaust, but all you'll need is some exhaust tape and it'll be fine, you could also make the exhaust dipfurther then normal to move it further away from the clutch but in the end its up too you.
Steve
AE86slut
Baulko Hillo
Re: A4-C To A4-GE Tue, 21 September 2004 00:44 Go to previous messageGo to next message
AE86slut wrote on Mon, 20 September 2004 14:26
Why would you want to go to all that bother when I have already told you the easy way to do it????
bubbles
Banned user
Liverpool NSW
Re: A4-C To A4-GE Tue, 21 September 2004 00:55 Go to previous messageGo to next message
Is the 4ac gearbox different from the jdm´s?
arent them both t50´s?
AE86slut
Baulko Hillo
Re: A4-C To A4-GE Tue, 21 September 2004 01:18 Go to previous message
They are the same apart from the bellhousing, which puts the clutch slave on the opposite side
Oh... ´s
Previous Topic:Cusco Safety21 Cage - Opinions
Next Topic:US 550cc 2jz injectors
Current Time: Thu Nov 19 14:11:21 UTC 2026
Total time taken to generate the page: 0.074218988418579 seconds
