Toymods » Tech & Conversions » 18rg,twin solex's. "help"
lilcrash
ipswich queensland
18rg,twin solex's. "help" Sun, 19 September 2004 08:33 Go to next message
ive got a 18rg in my corona and was wondering if neone can tell me how to tune then easily
also y would it be over heating. it goes up to the white line and just stays there.
thanx
munki
Gold Coast
Re: 18rg,twin solex's. "help" Sun, 19 September 2004 11:33 Go to previous messageGo to next message
get a carby balancer and an 18r toyota factory manual and go to town.
as for overheating there are several white marks on my temp guage which one?
lilcrash
ipswich queensland
Re: 18rg,twin solex's. "help" Sun, 19 September 2004 21:43 Go to previous messageGo to next message
my temp guage goes all the way to the top blank then there is a white then a red line right next to each other
so about 5-6mm from the top of the guage
river
Land of Oz
Re: 18rg,twin solex's. "help" Sun, 19 September 2004 22:58 Go to previous messageGo to next message
My 18RG runs a fraction under 80 Degrees Cels. It goes a little over the 80 mark then the thermostat opens and she drops down.
If it's really hot and I'm running the air con, then it goes a little over 80.
seeyuzz
river
lilcrash
ipswich queensland
Re: 18rg,twin solex's. "help" Mon, 20 September 2004 00:17 Go to previous messageGo to next message
i took my thermostat out and put it in a pot of water and put in on the stove, the water was starting to boil wen she finally opened up
is this a bad thing???
Jason
Re: 18rg,twin solex's. "help" Mon, 20 September 2004 02:50 Go to previous messageGo to next message
You already have your thermostat out so just replace it with a new one.
You can do a very basic tune yourself by buying one of those cheap vac guages from supercrap auto and matching the carbies but a proper tune should be done by a professional on a set of rollers/dyno.
drift86levin
brisvegas
Re: 18rg,twin solex's. "help" Mon, 20 September 2004 03:13 Go to previous messageGo to next message
i've got a shop manual for the 18R-G..the diagram shows a dual vaccume gauge (just buy 2 cheap ones i guess) and it t-pieces off to both barrels before the balance tube..so you tune each carb, not each barrel..i'll have a look at it tonite to make sure..also if anyone wants a copy of this (enough info to rebuild the motor) just ask
Petes76celica
Re: 18rg,twin solex's. "help" Mon, 20 September 2004 09:44 Go to previous messageGo to next message
i would appreciate it if i could have a look at that manual as i am in the progress of tuning my carbies at the moment
Pete
brett_celicacoupe
townsville NQLD
Re: 18rg,twin solex's. "help" Mon, 20 September 2004 09:55 Go to previous message
go off ure spsark plugs,
black means u got to lean it out a bit
brown means its runnin rite fuel/ air mix
white means u have t oritchen it up a bit
ull have to clean it after evertime u drive it though
good luck anyway
brett
Previous Topic:grafting another dash into an ra40 celica
Next Topic:Supra JZA80 clutch master and slave cylinder bore sizes
Current Time: Thu Nov 19 23:20:22 UTC 2026
Total time taken to generate the page: 0.00649094581604 seconds
