Toymods » Tech & Conversions » Blinkers Earthing
ta2272
icon2.gif  Blinkers Earthing Sun, 19 September 2004 08:59 Go to next message
Blinkers are not working and i was told to make sure the earth is not faulty how do i check or replace the earth (make anothere one) to see if they work then.
Jason
munki
Gold Coast
Re: Blinkers Earthing Sun, 19 September 2004 12:14 Go to previous messageGo to next message
is the earth just the body of the blinker to the metal? if so bolt it in a different spot?
ta2272
Re: Blinkers Earthing Sun, 19 September 2004 12:29 Go to previous messageGo to next message
so your saying the earth is at each blinker?
SeptemberSquallIndustries
Re: Blinkers Earthing Sun, 19 September 2004 12:58 Go to previous messageGo to next message
Yes, it's a one-wire type which earths through the body.
TA22 GT
Re: Blinkers Earthing Sun, 19 September 2004 13:02 Go to previous messageGo to next message
Yep, each of the front blinkers on a TA22 is earthed through the blinker housing onto the panel.
The rear blinkers are earthed through the main earth wire which is white and black.
If nothing is working, weg on your dash rear light or front, then the blinker box itself could be stuffed (I would try changing this first), or it could be an earthing problem. But its unlikely to be a local earth fault if the rear blinkers or dash lights aren't working either.
Also, check the big plug under the steering column, its blue/black and white from memory. Its where all the main wiring is connected, A bad contact there will also cause this fault.
In fact, that plug has caught me out a couple of times now where I spent ages looking for faults when it was a bad contact in that plug all along.
Hope this helps,
Simon
ta2272
Re: Blinkers Earthing Sun, 19 September 2004 14:41 Go to previous messageGo to next message
well the blinker lights work because my hazrads work, should i still be looking for a earth fault.?
TA22 GT
Re: Blinkers Earthing Mon, 20 September 2004 11:21 Go to previous messageGo to next message
It can't be an earth fault, I would check that plug I was talking about.
Simon
ta2272
Re: Blinkers Earthing Mon, 20 September 2004 13:43 Go to previous messageGo to next message
Have booked it into the auto electrics for wed but will have a go at that plug how do you sugget i test it?
it is the six pin one isnt it green wires.
Jason
Re: Blinkers Earthing Tue, 21 September 2004 06:00 Go to previous messageGo to next message
No, that's the headlight relay. I think he's talking about the main loom plug under the steering column.
TA22 GT
Re: Blinkers Earthing Tue, 21 September 2004 12:48 Go to previous messageGo to next message
Yeah, I mean the main loom plug. It has heaps of wires going to it. Its black, blue and white and is under the steering column.
Turn your blinkers on and then twist that plug to see if its caused by a loose connection. Better still, unplug it and check water hasn't got in it and started corroding the connectors.
Simon
ta2272
Re: Blinkers Earthing Wed, 22 September 2004 11:51 Go to previous message
Ok it cost me $25 at the auto electricians there was a faulty connection at the flasher unit were the blinkers recieved its powere.
thank you for all your help.
Jason
Previous Topic:say I had different # of teeth on my driveshaft than in my diff
Next Topic:Porsche 1977----Help ma pls!
Current Time: Sun Oct 25 06:46:18 UTC 2026
Total time taken to generate the page: 0.0055010318756104 seconds
