Toymods » General Car Talk » Need tips on panel beat n spray
jeffro RA28
Tamworth
Need tips on panel beat n spray Sun, 19 September 2004 10:10 Go to next message
Hey
just doing up an 77 RA28
it needs some minor panel beating and a full respay job, just wondering if any 1 out there has got a few tips on the prep i can perform to reduce the cost for labour. To use paint stripper or sanders?
the car is now bare, just the shell and motor.
some pics. http://au.msnusers.com/jaffa_hally@hotmail.com/doc uments.msnw?fc_p=%2FMy%20Pictures&fc_a=0&p ps=k
and picture number 20 is a picture of the dash, if any one knows of a dash making service can u please let me know.
if u could help it would be great:)
l8ers:)
TA22 GT
Re: Need tips on panel beat n spray Sun, 19 September 2004 13:05 Go to previous messageGo to next message
Check out my site, look at "Technical info". I have painting tips there.
Simon
brett_celicacoupe
townsville NQLD
Re: Need tips on panel beat n spray Tue, 21 September 2004 23:42 Go to previous messageGo to next message
a good way to rip the paint off fast is to go and but a $99 230mm grinder from bunnings and buy a 200mm backing disc (for sticky discs) and buy a few 200mm sticky discs that are 36 grit. this ripps it off good. u gotta becareful about goin over edges with these things thoug, u can ripp them easy.
if you are gunna use this method, u will need to spray ure car with etch primer.
hope this helps ... good luck
brett
1g-gte-ra28
Re: Need tips on panel beat n spray Wed, 22 September 2004 10:18 Go to previous message
to remove the old paint Id sugest u use paint stripper. Simply remove or mask up all crome and plastic trims scuff the surface up first with a bit of 80 grit till there is no shine then apply the stripper and cover it with some plastic and wait till the paint starts to lift depending on the number of coats of old paint you may need to repeat this. once all of the old paint is gone get some old rags and some thinners and wipe the panel clean then orbital sand with 80 grit to remove any remaining litte bits of old paint. Using grinders with 36 grit tends to scar the metal and if you dont know what you are doing heat it up causing panel damage. Sand blasting will generally provide disasturous results on exteriour panels but is excellent for engine bays and door jambs I have been through 3 sandblasters and I am yet to see a car that has been sandblasted that isnt fucked as a result, the people who do this type of work seem to be heavy handed morons who dont give a shit about light gauge panels. Coat all panels with a good quality etch primer and dont leave out in the weather. The panels will be then ready to be Panel beaten. If you are going to be bothered to do this dont waist your time, paint it in a good quality 2 pack and itll last for ages Very Happy
Previous Topic:whot economy are u guys getting?
Next Topic:Im new here
Current Time: Wed Nov 18 07:08:04 UTC 2026
Total time taken to generate the page: 0.0062880516052246 seconds
