Toymods » General Car Talk » general turbo question
tyottsoarer
Gold Coast
general turbo question Sun, 19 September 2004 12:58 Go to next message
Ok so i went and read up about how a turbo works and after reading this i got to wondering, Is the power a turbo adds to your car relative only to the boost it supplys or does the size of the turbo also contibute to the power it makes, and if so how?
Spanktown
Inside a giant turbo (syd...
Re: general turbo question Sun, 19 September 2004 13:00 Go to previous messageGo to next message
simple. Bigger turbo flows more air at the same psi as a smaller turbo. Also turbo efficiency at said boost level comes into play as well.
dimmy77_03
Potts Point, Sydney
Re: general turbo question Sun, 19 September 2004 13:05 Go to previous messageGo to next message
yeh...size does matter. Smaller turbo's provide boost earlier, and the larger ones boost later on. That's what i've always thought anyway Razz
tyottsoarer
Gold Coast
so running a larger turbo at the same pressure as a smaller one will result in more power, because it is moving more air at that pressure to the engine?
Spanktown
Re: general turbo question Sun, 19 September 2004 13:08 Go to previous messageGo to next message
hah, thats atleast what i think....
but also more peak power because generally a larger turbo will take longer to spool, so you will get a steeper power curve.
TA22 GT
Re: general turbo question Sun, 19 September 2004 13:11 Go to previous messageGo to next message
Yep, a bigger turbo at the same boost as a small one will give more power.
BUT, bigger is not always better. The bigger it is the more lag it also has. So although you get more power you are also waiting for a higher rev range before the power really comes on.
Too big is not good for street use as the rev range is too high.
It really depends on what you want. I have a GT25 (320hp) on my 3T GTE and it comes on boost very fast at the expense of top end power. This is great for street use as I get maximum power from around 2500 to 5000rpm instead of a big turbo coming on around say 4500rpm to maybe 7000rpm.
Hope this helps,
Simon
dimmy77_03
Potts Point, Sydney
Re: general turbo question Sun, 19 September 2004 13:13 Go to previous messageGo to next message
TA22 GT wrote on Sun, 19 September 2004 23:11
that's what im talking about.
Check out http://howstuffworks.com
tyottsoarer
Gold Coast
but if your moving more air through the same space (intercooler piping) as the smaller turbo was using then shouldnt the pressure (psi) go up cause you have more air in the same volume ie higher boost? meaning the power IS relative only to the boost?
Spanktown
Re: general turbo question Sun, 19 September 2004 13:23 Go to previous messageGo to next message
that depends on where you are measuring the boost...
tyottsoarer
Gold Coast
Re: general turbo question Sun, 19 September 2004 13:26 Go to previous messageGo to next message
I see, my concept of boost measurment must be wrong. So where does the waste gate get its measurment of boost, because isnt that what governs maximum boost of the turbo?
TA22 GT
Re: general turbo question Sun, 19 September 2004 13:27 Go to previous messageGo to next message
tyottsoarer wrote on Sun, 19 September 2004 23:13
OK, you're missing a couple of important factors. Firstly small and big turbos push different amounts of air at different rev ranges. EG the small turbo will push MORE air early on and a big turbo will out puffa small turbo once the revs pick up. So there are trades offs either way, either you get low end power or more top end power.
In some ways Boost is just a measure of engine back pressure. Boost of 10psi with a small turbo doesn't mean the same air flow etc with 10psi with a bigger turbo, same can be said for ported heads, pipework restrictions etc. Turbo selection is not that easy and alot of factors need to be considered. So dont be fooled that bigger is better when it comes to turbos. So this also means that just talkign about boost alone doesnt mean that more boost = more power. Too much boost and you will start generating too much heat = less power. Theres no point pushing hot air into an engine.
Simon
tyottsoarer
Gold Coast
Re: general turbo question Sun, 19 September 2004 13:51 Go to previous messageGo to next message
I'm begining to understand
Re: general turbo question Mon, 20 September 2004 00:31 Go to previous messageGo to next message
What everyone is missing here is the exhaust side of the equation. The main reason a small turbo will make less power than a large turbo at the same boost pressure and the same rpm is the exhaust restriction. Look at the exhaust housings on a stock 1JZ turbo - they're TINY. You can pump as much boost as you like in the inlet side, but if you can't get the exhaust out the other side it's a big waste of time.
So yes it's all about flow, but you have to consider the overall flow from one end of the engine to the other, not just the inlet side.
Skip
Re: general turbo question Mon, 20 September 2004 05:12 Go to previous messageGo to next message
What norbie said Smile
Another way to look at it is if you had a supercharged engine with say 1" primary extractors running 10psi. You then put a bigger supercharger on, 10 psi but use 2" primary extractors = more power. More flow through the system as the exhaust side is freed up.
tyottsoarer
Gold Coast
Re: general turbo question Mon, 20 September 2004 11:31 Go to previous message
it is clear to me now Surprised thanks a lot Very Happy
Previous Topic:my ke30 with sprayed ke30 rims
Next Topic:Just bought AE92...need wheels and suspension-Where in bris?
Current Time: Thu Nov 19 06:38:09 UTC 2026
Total time taken to generate the page: 0.0061450004577637 seconds
