Toymods » Tech & Conversions » Sub and Amp question
old_mr2
Sub and Amp question Mon, 20 September 2004 08:48 Go to next message
Guys
my 10inch sub is playing silly buggers. I have an audio gods 200W amp and a clarion sub.
I start the car and it works fine. Big bass. Then it will just stop working and not work again until I start the car again (or just switch to acc). It happens very intermittantely. Sometimes it doesnt happen??
Does anyone know what could be causing this. Its really annoying!
Thanks in advance
drift86levin
brisvegas
Re: Sub and Amp question Mon, 20 September 2004 09:02 Go to previous messageGo to next message
what gauge power wire are you running? i had tiny 12 gauge on my orion 12" DVC and nice cobolt amp..it kept cutting out..and going into safe mode (light on the amp would change from green to red)..try upgrading your wire..maybe some 8 gauge..thats all i can think of..check fuses and connections too
mat
[Updated on: Mon, 20 September 2004 09:04]
old_mr2
Re: Sub and Amp question Mon, 20 September 2004 09:45 Go to previous messageGo to next message
Thanks mate. Im using the wire (unsure of its gauge) that came with a professional installation. And it worked fine for 2 years in my old mr2.
I recently transfered all the gear over to my new mr2 exactly the way it was and now this is happening? I cant work it out.
[Updated on: Mon, 20 September 2004 10:50]
toof
Re: Sub and Amp question Mon, 20 September 2004 10:33 Go to previous messageGo to next message
what sub/box combo are you using an where are you mounting the sub ? im assuming you have an aw11 ?
old_mr2
Re: Sub and Amp question Mon, 20 September 2004 10:49 Go to previous messageGo to next message
yeah dude its an aw11. Its a Clarion 400W 10 inch in a Newcastle Pro sound box. Very similar to this
http://www.lightav.com/car/boxes/xscorpion/x100_12.jpg
chrishulbert
Castle Hill NSW
Re: Sub and Amp question Tue, 21 September 2004 01:58 Go to previous messageGo to next message
Its overheating and going into safe mode, probably. Same thing happened to me.
Either that, or:
Have you got your amp bridged? If so, that'll be why its overheating. If you bridge cheap 2 channel amps into a single sub then they cut out all the time like yours is. Again, same thing happened to me.
old_mr2
Re: Sub and Amp question Tue, 21 September 2004 03:00 Go to previous messageGo to next message
Thanks for the reply mate yes I am bridging! I will look into that.
The amp I have now is a cheapy, however it used to happen more often with my old Blaupunkt 200W (not so cheap)
Its funny, shes been working fine for the last 2 days, touch wood, I would rather not fiddle with it while its working.
As soon as she goes down again I will take it off bridge mode. My amp sits under my drivers seat perhaps it is a little hot down there. However the problem somtimes occurs afteronly driving the car for 90 seconds (cold)
nick2b
Re: Sub and Amp question Tue, 21 September 2004 03:31 Go to previous messageGo to next message
Also check if you have tightend the ground cable up becuase that could be your problem as well.
old_mr2
Re: Sub and Amp question Tue, 21 September 2004 06:02 Go to previous messageGo to next message
Thanks nick. I used the same ground point in my new MR2 as the pro installers did in my old one. I even sanded it a little to ensure a connection. However I might try a different point also.
nick2b
Re: Sub and Amp question Wed, 22 September 2004 08:27 Go to previous messageGo to next message
No probs im installing a system into a 84 mazda 929 on sat how exciting. Evil or Very Mad
digitalpho3nix
St James, Perth
Re: Sub and Amp question Wed, 22 September 2004 10:18 Go to previous message
I agree with chrishulbert. That is most likely an overheating issue. If it happens even when the car is cold, perhaps you have damaged the equipment from being too hot, or something has come loose over time? (eg, wiring, ground bolts, internal component?)
GL with fixing it!
DP
Previous Topic:Old style AVC-R wiring help
Next Topic:mitsubishi 3l V6 question
Current Time: Fri Nov 20 06:50:32 UTC 2026
Total time taken to generate the page: 0.0072231292724609 seconds
