Toymods » Tech & Conversions » 3SGE 3SGTE bellhousings
KinLoud
Hamilton, NZ
3SGE 3SGTE bellhousings Mon, 20 September 2004 11:03 Go to next message
I've had a couple of inquiries about 3SGE or 3SGTE bellhousings to fit W series gearboxes.
I've sold some to people here in NZ and a couple to OZ.
I'm no longer keen to find them at wreckers, clean them up, box them up and send them off to people all over the place.
I took me quite a bit of searching and a bit of luck to work out what fitted what and where to find them - I hope lots of people benefit from my efforts.
If you copy this to other websites I ask that I am acknowledged as the author of this info.
I take no responsibilty for any problems you might encounter if you use this info.
3SGE or 3SGTE BELLHOUSINGS TO FIT W series GEARBOXES
You can have starter on left or right.
Starter on left.
Look for a bellhousing out of any manual C motor powered rwd toyota. This is identical to the S to W bellhousing! Probably the most common would be diesel powered LiteAce or maybe HiAce.
Get the slave cylinder and clutch release arm. Get the bellhousing to block support brackets and the metal companion plate that fits between bellhousing and block. these will suit the S motor as well.
Starter might fit as well I think.
OR
Starter on right
Look for a bellhousing out of any manual Y motor powered rwd toyota. This is very similar to the S to W bellhousing. Probably the most common would be LiteAce or maybe HiAce.
Get the slave cylinder and clutch release arm. Get the metal companion plate that fits between bellhousing and block. these will suit the S motor as well.
Starter fits but might cause problems in AE86. The bellhousing to block support brackets... not sure if they fit, can't remember sorry.
"BUT" you say, "the LiteAce and HiAce has a G series gearbox not a W!"
No problem - the front bolt pattern of the G series gearbox is exactly the same as the W series gearbox. Bolt it up and be happy!
If you have a Y series bellhousing? That will work well and give you the starter on the right. You just need to slot or fill and redrill one hole and it will fit the S series motor fine. You might need to mill 5 to 10 mm off the face of the bellhousing - see below.
With a factory S motor to W gearbox setup, the pilot bearing sits in the centre of the flywheel instead of the centre of the crankshaft.
This means that you have to:
1 - mill 5 to 10 mm off the face of the bellhousing so the input shaft will reach into the end of the crank (you would have to insert a pilot bearing into the end of the crank). OR
2 - fit a pilot bearing into the centre of the flywheel. OR
3 - find a bearing that is wider than the standard pilot bearing so half of it sticks out beyond the end of the crankshaft enough to accept the input shaft.
4 - make an adapter that fits into the end of the crank. This adapter holds the pilot bearing 5 or 10 mm out from the end of the crank so the inout shaft will fit into it.
Starter motors - The starter motors from rwd S or C motors should fit the C or S bellhousings ok I think. The starter motors from the Y motors might be ok, not really sure. Gabe from WA says he had to use another starter (I don't know what one) to keep clear of the AE86 steering.
Good luck
Kinloud
Ken Evans
Taupo
New Zealand
no_tofu_speed
Jab what?!!?!
Re: 3SGE 3SGTE bellhousings Mon, 20 September 2004 17:26 Go to previous messageGo to next message
Wow!
So informative, I am too lazy to read it right now
3:30am, so I have filed it!
Thanks heaps in advance!
rob_RA40
c'town, NSW
Re: 3SGE 3SGTE bellhousings Mon, 20 September 2004 22:27 Go to previous messageGo to next message
Nice work Ken, very informative!
Ed please put this in the FAQ
gabe
Re: 3SGE 3SGTE bellhousings Tue, 21 September 2004 01:17 Go to previous messageGo to next message
Very helpful Ken, much appreciated.
Like you mentioned, I don't know what starter I used as I had a few lying around and tried them all till I found one that was right.
If it is required, I will pull my starter off and take it to the wreckers and match it up. But like I said, only if it is required....
Once again Ken, cheers for taking the time to document all that info for us!!
Gabe
Re: 3SGE 3SGTE bellhousings Tue, 21 September 2004 02:04 Go to previous messageGo to next message
I used a starter from an SA63.
gabe
Re: 3SGE 3SGTE bellhousings Tue, 21 September 2004 02:13 Go to previous messageGo to next message
Cool1 wrote on Tue, 21 September 2004 10:04
Yep a SA63 will fit but if you are transplanting the engine into a sprinter, the starter sits too far out from the block and fouls the steering.
Old Celicas and the like have a steering box, so the whole setup is much more compact. As you know
Re: 3SGE 3SGTE bellhousings Tue, 21 September 2004 02:15 Go to previous messageGo to next message
Actually the late/replacement SA63 starters are about as small as you'll get which is what I needed to clear my engine mount.
KinLoud
Hamilton, NZ
Re: 3SGE 3SGTE bellhousings Tue, 21 September 2004 08:50 Go to previous messageGo to next message
When you mention SA63... in OZ is it a Celica or Carina?
Was it sold new in OZ or is it an import?
I presume it has a Gen 1 3sge?
I have an AA63 Carina racecar. Its a 3 door fastback, sort of a cross between a celica and corona. Has factory 4age, T50, independant rear, 4 wheels disks. I also have a couple of AA60s - same body but 3a motor and solid drum rear (parts cars for my race car in case I bend something).
Here in NZ the trend seems to be putting a 3sgte into an early 80's rwd Toyota Starlet - 750 kg of hair raising fun!
Ken
Taupo
NZ
Re: 3SGE 3SGTE bellhousings Tue, 21 September 2004 08:59 Go to previous messageGo to next message
The SA63 in Oz is a Celica which comes packed with a 2SC Smile
What do the 80's rwd Toyota Starlets look like?
Purple_Beasty
New Zealand
Re: 3SGE 3SGTE bellhousings Tue, 21 September 2004 09:44 Go to previous messageGo to next message
http://www.onlinemotorsport.net/For%20Sale/StarletCircuit1.jpg
Re: 3SGE 3SGTE bellhousings Tue, 21 September 2004 09:47 Go to previous messageGo to next message
Wow, one of those would be sweet with a 3S-GTE fitted Shocked
How much do they sell for over there? Unmodified?
Purple_Beasty
New Zealand
Re: 3SGE 3SGTE bellhousings Tue, 21 September 2004 09:57 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=43802&start=0&rid=129&S=3ba0cd0e262b e5a87203b5ac808d8659
Prices for a standard really depend on the over-inflated expectations of the seller. Seen nice ones go cheap (mine was $200 with minor accident damage but bugger all rust), and seen crap ones go for ridiculous prices.
Callum
KinLoud
Hamilton, NZ
3SGE 3SGTE bellhousings Thu, 23 September 2004 09:50 Go to previous messageGo to next message
RWD Starlets often sell for $1000 to $1200NZ
I have seen some real mint ones including a genuine One Lady Owner 1984 Starlet - only probs where faded paint and a small dent on front guard. Most are a bit rough with rust and dents.
You could import one to OZ with no probs due to it being older than 15 years or is it 20 years.
Ken
Taupo
NZ
Re: 3SGE 3SGTE bellhousings Thu, 23 September 2004 10:06 Go to previous messageGo to next message
I wouldn't mind one of them to play with. How much would a container cost?
wagonist
Toymods Club Treasurer
Re: 3SGE 3SGTE bellhousings Thu, 23 September 2004 10:45 Go to previous messageGo to next message
I'd have a think about one of these too.
Would have to bring in 2 for each person as we couldn't get spares.
Re: 3SGE 3SGTE bellhousings Thu, 23 September 2004 11:12 Go to previous messageGo to next message
Why would you need spares? Everything gets custom made so its no problem.
wagonist
Re: 3SGE 3SGTE bellhousings Sun, 26 September 2004 22:44 Go to previous message
I'm talking about body panel spares.
Previous Topic:3SGTE Knock sensor?!
Next Topic:17" rims and tires on a 1990 camry
Current Time: Sun Oct 18 01:15:57 UTC 2026
Total time taken to generate the page: 0.010339021682739 seconds
