Toymods » General Car Talk » if it rattles...
jesseT18
Castle Hill, Sydney
if it rattles... Mon, 20 September 2004 11:42 Go to next message
lately i've been getting lots of comments from passengeres about the rattles in my car being lounder than the music and exhuast, that aint right!
how's everyone else de-reattle their old beasts
i've been removing all the 'luxury' items like centre console and the shelf and im thinking about taking out the 2 big plastic covers at the bottom of hatch and the back of car, theyre pretty dam rattly
so if it rattles, take it out?
this is obviously only going to go so far until my car looks like its living in a wrecking yard
Shraka
Re: if it rattles... Mon, 20 September 2004 12:04 Go to previous messageGo to next message
Could you just screw it down tighter? Very Happy
jesseT18
Castle Hill, Sydney
Re: if it rattles... Mon, 20 September 2004 12:07 Go to previous messageGo to next message
yeah thats always an option, its got the plastic clips but i could chuck in a pile of self tappers everywhere...
ok its decided, project rattle has began, lets see how quiet i can get the old girl, ill start at rattly windows, plastic panels, and gear knob, theyre the bad ones!
inertia
Re: if it rattles... Mon, 20 September 2004 12:41 Go to previous messageGo to next message
How bout finding the rattling bits and glue some chopped up sponge/foam in there to see if it stops it?
Might be more asthetically pleasing than self tappers.
ae86drift
sydney.au
Re: if it rattles... Mon, 20 September 2004 12:44 Go to previous messageGo to next message
haha my whole car damn rattles
SIMDOG
Bayside Melbourne.
Re: if it rattles... Mon, 20 September 2004 13:18 Go to previous messageGo to next message
That is one of the most annoying things with old cars... All the plastic bits start to get loose.
I have eliminated all but the bootlid spring and something in the rooflining that rattles when the sub goes. It is a total bitch to track them all down. Sad
Siktoy ra23
Plumpton/sydney
Re: if it rattles... Mon, 20 September 2004 13:22 Go to previous messageGo to next message
I had a datsun 1200 coupe and the boot lid rattled that much that it would pop open if I turned the music up to much
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: if it rattles... Mon, 20 September 2004 15:43 Go to previous messageGo to next message
lets have a rattle off
my car, HAS to be the worst for interiour noises. i get rattles, clunks, bangs, whines, whirs, squeaks and even meows coming from the car
meow's cause the fucking cat next door walks on the bonnet
Lambolica
Northwestern Sydney
Re: if it rattles... Mon, 20 September 2004 23:56 Go to previous messageGo to next message
Yeah the rattles are a bitch, be prepared to spend countless hours pulling interiors apart screwing back together only to have the same or another noise appear.
Alot of noises can be cured by placing a thin layer of foam between the metal and the interior panel (plus added sound proofing). the metal push plugs similar to that used in early door trims wear through the plastic inserts that can be easily replaced with new inserts.
If it rattles it, or somthing holding, screwed, glued to it is worn out and needs renewing, not necessarily removal. Over time the bigger rattles can be eliminated and you can sort through the smaller less annoying noises. And those pesky noises that only appear at 3500rpm and driving at 110km/h that just s#@t me
Joshstix
Toymods Vice President
Re: if it rattles... Tue, 21 September 2004 00:59 Go to previous messageGo to next message
I had a terrible rattle from the instrument binnacle of my MR2. I pulled the cover off and spayed the inside with bdoy deadener including all of the area's where it buts up against other trim but not on the screw down points. Now it doesn't make a sound.
This work for two reasons:
  1. It added more tension to the screws as the point of contact with other trim was moved out further
  2. It added mass to the part that was vibrating wich changes the resonant frequency as well as making it require more energy to move the component
Of course you can use proper interior insulation either sheets or spray on stuff for this, I only used body deadener because I had a can laying around from tidying up my engine conversion.
jesseT18
Castle Hill, Sydney
Re: if it rattles... Tue, 21 September 2004 06:43 Go to previous messageGo to next message
hmmm i think i'll just track down the bad ones and sort them out, dont want to be adding kg's of sound proofing to the car :S
Callifo
Gawler, SA
Re: if it rattles... Tue, 21 September 2004 07:31 Go to previous messageGo to next message
Ive got two which shit me off, one is a rattling which occurs on basically ever bump on the road. The second is a whistling which starts at 80km/h and stops at about 110km/h. Havent been able to find either of them yet.
wolf
Hills, Sydney
Re: if it rattles... Tue, 21 September 2004 07:46 Go to previous messageGo to next message
I've got this problem with my MKIII.
There is a rattle in the rear, took the whole boot plastic appart went for a drive. It was still there. So when I took it to the mechanic for a tune-up I told him about it. Dont know what he did but the noise was gone. After an hour of driving the noise started to come back, due to pot holes and gap's in the asphalt. Roads in the Hills District's fucking suck.
Otherwise, there are vibes around passenger door, dash plastic, buzzing electrical noise under the steering wheel... and so on an so forth.
I would love to fix them but that would require a garage spot and a couple of weeks of searching (a re-build basicaly). Something wolf is pov about with time and money.
This has taught me to investigate where and how the car has been driven before I buy it.
79rollaboy
NSW Engadine
Re: if it rattles... Wed, 27 October 2004 09:15 Go to previous messageGo to next message
I wanna put stuff in my boot to stop some of the exhaust noise...
I was thinking... cheapo ex-clothes soundproofing material... or proper underlay stuff... or the spray on stuff which works best...
bathurst-91
Re: if it rattles... Wed, 27 October 2004 09:38 Go to previous messageGo to next message
I have mice sex noises.
Laughing
Well thats what it sounds like but its actually the right rear damper squeaking at the hole where it enteres the body. I cant be stuffed fixing it.
And theres plenty of rattle =p
jonchai
Adelaide - Race Central
Re: if it rattles... Wed, 27 October 2004 09:56 Go to previous messageGo to next message
I've more rattles in my car than the toys department at Target. Given up within 3 months of ownership. one leads to another and another and another......just make sure it ain't from the engine and you're fine mate!
optionUP
Perth, WA
Re: if it rattles... Wed, 27 October 2004 15:39 Go to previous messageGo to next message
What a relief to know everyone has the same problem!
Some of the noises my Sprinter makes drive me nuts - like the constant rattle at any speed that I lived with for 2 months, until the mechanic worked out it was loose handbrake cables - tightened 'em up and thank God it went away. Still got a rattle/vibration that crops up around 3000 - 3200 rpm in all gears. Still, I can live with that one.
paddles
Re: if it rattles... Wed, 27 October 2004 22:13 Go to previous messageGo to next message
Silicone is your friend, unscrew the rattly bit, whack a bit of silicone under there and screw the now non-rattly bit back down. Works a treat Smile
Skaney
Re: if it rattles... Thu, 28 October 2004 00:08 Go to previous message
I got plenty of rattles.
AE86s with stiff shocks, springs/coilovers, stretched tyres will do that.
Previous Topic:moving to S/E QLD
Next Topic:email pettion kinda thing: RPM to televise JGTC
Current Time: Fri Nov 20 14:55:48 UTC 2026
Total time taken to generate the page: 0.02537989616394 seconds
