Toymods » Tech & Conversions » can a 1J spin up a T77 with a 1.32 back?
mx83toy
can a 1J spin up a T77 with a 1.32 back? Mon, 20 September 2004 13:28 Go to next message
someone was saying they it couldnt do it effectivly i think it should get up and boggie at around 4000 rpm??? what are your thoughts??? no plans here we were just chattin... anyone seen a 1J go with a T77?????
[Updated on: Mon, 20 September 2004 13:29]
Bentt
Re: can a 1J spin up a T77 with a 1.32 back? Mon, 20 September 2004 22:46 Go to previous messageGo to next message
Ummm, I haven't had experience with this turbo, and I am not proficient enough to run it through engine analyser yet, However A T70 wheel as far as I know isn't suitable for a 1jz...
http://www.moreboost.org/turbos.htm
This site says it's not suitable for the 2jz, due to surge. However with a monstrous 1.32 rear housing, you might find it won't surge but you'd probably find it would take longer to spool. I wouldn't be expecting decent boost by 4000rpm.
It is all speculative however, and you can do all the calcs in the world, only true way to find out is to try it Smile
drift86levin
brisvegas
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 04:50 Go to previous messageGo to next message
it would be worth looking at the cams..i don't know much about the 1JZ (other than they are very tough!)..but a trick that us small capacity 4 bangers do..open up the cam timing..the less over lap the better..and if you can the exhaust cam can be redone with a bit more duration on the exhaust..that will bring her on boost quicker..
just a thought..
mx83toy
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 05:19 Go to previous messageGo to next message
ccol...i'll give it a try one day Laughing
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 06:16 Go to previous messageGo to next message
Anything is possible with a big enough hit of gas. Wink
drift86levin
brisvegas
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 06:24 Go to previous messageGo to next message
Laughing Laughing Laughing
a 50 shot of nos would bring it on nicely!
[Updated on: Tue, 21 September 2004 06:25]
mx83toy
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 07:42 Go to previous messageGo to next message
would that explain the weird spool up time when i back the timing off seems to come on to boost really quick sometimes especially when i increase the fuel!!!
MR 1JZ
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 07:58 Go to previous messageGo to next message
drift86levin wrote on Tue, 21 September 2004 14:20
just a thought..
would this work on my 1GGTE? cos the lag is not what you would call errr light.... Rolling Eyes
mx83toy
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 08:10 Go to previous messageGo to next message
if you have stock turbos....sell your boost controller to some one and buy a HyperBoost one that celicamad builds they work great get rid of lag by holding your wastegates shut... they work well!!!
MR 1JZ
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 08:26 Go to previous messageGo to next message
Would it be a direct swap with my Bleed Valve, i.e. could I pull the hoses off the bleed valve and insert the hyperboost one? Confused
mx83toy
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 09:42 Go to previous messageGo to next message
yep thats it...10mis and your off!!!!
drift86levin
brisvegas
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 09:47 Go to previous messageGo to next message
MR 1GGTE wrote on Tue, 21 September 2004 17:58
just a thought..[/quote
yeh mate sure could..if everything else is tops..get some adjustable cam gears would be the way..and try and minimise the overlap..overlap is the time that both the inlet valves and the exhaust are open (from memory the 1JZGTE has about 5deg of over lap) so thats a brif amount of time where boosted air goes in and straight out the exhaust!
but say 5deg more duration..and less overlap..makes a huge difference..
MR 1JZ
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 10:09 Go to previous messageGo to next message
drift86levin wrote on Tue, 21 September 2004 19:17
Adjustable cam gears....right....bit hard to find them...is there any other way to do it without the adjustables???
drift86levin
brisvegas
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 10:41 Go to previous messageGo to next message
short answer.. no with a but
long answer.. yes with an if
make it an adjustable one.. you just need 2 of the same 1G pullies.. i machine shop/engeneering shop would do it..
captain chaos
in the shadows
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 10:48 Go to previous messageGo to next message
if your 1j had a stroked capacity of around 4 litres (i.e maybe grafting a 1j head onto something resembling a landcruiser engine),a 1.32 would work ok. with VERY clever exhaust manifold designing it just may work with the limited exhaust pulse pressure available on the 1j. But, who wants to be the one to spend the money and try???? Confused
Joshstix
Toymods Vice President
Re: can a 1J spin up a T77 with a 1.32 back? Tue, 21 September 2004 22:32 Go to previous messageGo to next message
mx83toy wrote on Tue, 21 September 2004 17:42
This is because when you retard the timing you are igniting the mixture closer to the exhaust port opening. Therefore you are pumping out a still burning mix into the exhaust manifold and turbos. This is basically how antilag systems work.
MR 1JZ
Re: can a 1J spin up a T77 with a 1.32 back? Wed, 22 September 2004 03:03 Go to previous messageGo to next message
drift86levin wrote on Tue, 21 September 2004 20:11
That is good to know, as I am probably gonna have a few spare motors on saturday Very Happy cheers for the help
snail
Re: can a 1J spin up a T77 with a 1.32 back? Wed, 22 September 2004 08:16 Go to previous messageGo to next message
I know that a 1J with a gt30 (.82 rear housing) starts to boost around 4000rpm and feels laggy on the road. Cant imagine 1.32 being any better?
mx83toy
Re: can a 1J spin up a T77 with a 1.32 back? Thu, 23 September 2004 10:20 Go to previous message
Razz yeah but when she comes out to play! Shocked -> Surprised -> Very Happy . byby GTR Twisted Evil
Previous Topic:Clutch Fork
Next Topic:i need starlet engine info..
Current Time: Sat Oct 31 18:46:31 UTC 2026
Total time taken to generate the page: 0.0067222118377686 seconds
