Toymods » Tech & Conversions » handbrake button
driftae86
perth
handbrake button Tue, 21 September 2004 06:00 Go to next message
how do you take the standard handbrake button off the handbrake in the ae86?
apparently you can unscrew it but it doesn't stick out far enough to get a good grip on it.
can anyone help?
Bobski
Re: handbrake button Tue, 21 September 2004 06:08 Go to previous messageGo to next message
hmmm mine did...was easy just use needle nose pliers or somethign if its a little tight, and turn in counter-clockwise direction Very Happy ....also i saw somewhere before people using the rear seat tilt foreward plastic nob things as a rally style handbrake button that doesent need to be pressed when used
Adam
driftae86
perth
Re: handbrake button Tue, 21 September 2004 06:16 Go to previous messageGo to next message
Bobski wrote on Tue, 21 September 2004 16:08
Adam
thats the plan Very Happy
driftae86
perth
Re: handbrake button Tue, 21 September 2004 06:28 Go to previous messageGo to next message
SORTED
thanks for your help
i used the wire cutter part of some pliers that i had
Bobski
well if ur gonna do it be carefull...because although it works every time in theory ...it doesent in real life...i was forced to put a spring pulling out the putton....ie against handle and lip....worked a lot better then
Adam
driftae86
perth
Re: handbrake button Tue, 21 September 2004 06:35 Go to previous messageGo to next message
Bobski wrote on Tue, 21 September 2004 16:28
Adam
dont quite know what you mean Confused
Bobski
Re: handbrake button Tue, 21 September 2004 06:43 Go to previous messageGo to next message
um forget that last bit...i messed up... Rolling Eyes i changed mine back to normal a while back and i cant remember what i did, but it involved a spring Cool ....mine kept locking sometimes without warning so anyways be carefull... Very Happy
Adam
driftae86
perth
Re: handbrake button Tue, 21 September 2004 06:47 Go to previous messageGo to next message
haha Laughing
ok, thanks mate Smile
4ageeza
Adelaide, drift capital
Re: handbrake button Tue, 21 September 2004 09:15 Go to previous messageGo to next message
Bobski wrote on Tue, 21 September 2004 15:38
Yeah all you have to do is unscrew the current button as explained, and remove the internal spring. Then unscrew the rear seat knob, cut it down a little then screw it onto the threaded shaft in your handbrake.
Then no more accidental thumb slips and subsequent handbrake sticking!
Alainve
Newcastle NSW
Re: handbrake button Tue, 21 September 2004 09:53 Go to previous messageGo to next message
i made a sleeve to replace the original handle with a fancy type macined inside that works like a normal spring handbrake but when you wound the button down it acts like its locked in witout any chance of ratcheting.
worked sweet in my old car i may consider making a limited run of 2-3 if anyone is willing to cover costs but i need a lever to cut down from your model car or similar.
Bobski
Re: handbrake button Tue, 21 September 2004 10:09 Go to previous messageGo to next message
hmm i dont really know what u mean but sounds good.....do u think u could post picture if u have one or possibly even draw a picture in MS Paint Very Happy i like original artworks
Adam
Alainve
Newcastle NSW
Re: handbrake button Tue, 21 September 2004 10:50 Go to previous message
ok its an alloy sleeve that replaces half of your current handbrake lever to make it the same size as original.
works like an original handbrake till you wind the button in so it holds itself in no ratchet is possible then. its complicated inside but works well can look flashy too depending on what style you choose
Previous Topic:The diesel 20V, intelligent answers please..
Next Topic:mz21 dvd install HELP!!
Current Time: Sat Oct 17 04:08:22 UTC 2026
Total time taken to generate the page: 0.11366295814514 seconds
