Toymods » Tech & Conversions » where does this bolt go?.....18r-g
brett_celicacoupe
townsville NQLD
where does this bolt go?.....18r-g Tue, 21 September 2004 10:47 Go to next message
have been puttin my 18r-g back together and cant figure out wherethis bolt goes. it has 14mm head, 10mm diametre, bout 10mm of thread and a copper washer.
thanx
brett
munki
Gold Coast
Re: where does this bolt go?.....18r-g Tue, 21 September 2004 10:56 Go to previous messageGo to next message
your kidding right? not even a picture!
brett_celicacoupe
townsville NQLD
Re: where does this bolt go?.....18r-g Tue, 21 September 2004 11:02 Go to previous messageGo to next message
sorry Sad nope. it seems to be from somewhere important seeing as it has a copper washer. maybe a oil bung for somewhere. im worried there is gunna be conseguences if i dont find a home 4 it
thanx anway Sad
brett
munki
Gold Coast
Re: where does this bolt go?.....18r-g Tue, 21 September 2004 11:51 Go to previous messageGo to next message
the only thing i could think of is gearbox drain or filler? cant remember if they are 14s though
not to plug a water fitting on the thermostat housing?
Re: where does this bolt go?.....18r-g Tue, 21 September 2004 12:39 Go to previous messageGo to next message
sump drain plug?
gearbox drain/fill?
fuel lines for carbies?
brett_celicacoupe
townsville NQLD
Re: where does this bolt go?.....18r-g Tue, 21 September 2004 23:22 Go to previous messageGo to next message
thanx......yeah it is from the motor becoz im puttin it back together and every bolt i took off i put in a glad clip top bag.
anyway, ill have another look again when i finish puttin it back together ...(waitin on head gasket, valve stem seals, cam cover gasket)
brett
Jason
Re: where does this bolt go?.....18r-g Wed, 22 September 2004 02:14 Go to previous messageGo to next message
Might be the one that goes on the block just above the idler sprocket. It blocks off the hole that is usually taken up by the upper chain squirter nozzel on the 18r-c.
people100
Rocklea qld
Re: where does this bolt go?.....18r-g Wed, 22 September 2004 09:39 Go to previous message
im with jason. Goes just above the oil pump drive shaft. Blocks a hole that goes up to the top of the block. also is used to hold the backing plate of the timing case to the block. I also had this prob with mine but sorted it easily enough.
Previous Topic:18rgeu question...Timing setup
Next Topic:MA61 - rusty floor of boot & spare tyre well
Current Time: Fri Nov 20 06:50:53 UTC 2026
Total time taken to generate the page: 0.026954174041748 seconds
