Toymods » Tech & Conversions » Swaybars?
wilbo666
Swaybars? Tue, 24 September 2002 22:31 Go to next message
On a RWD car which would be the best sway bar to get first?
The front one looks to be quite large (23mm) but the back one looks tiny. How much differance will a front / rear swaybar make?
GIN51E
Berowra-Sydney
Re: Swaybars? Tue, 24 September 2002 22:45 Go to previous messageGo to next message
i think front reduces understeer and back reduces oversteer, but i'm probably wrong on this one never looked into the matter my theory is just put sway bars front and back Very Happy
wagonist
Toymods Club Treasurer
Re: Swaybars? Wed, 25 September 2002 01:05 Go to previous messageGo to next message
Rear wheel drive needs to have a lot smaller bar on the rear than the front unless you like sudden unpredictable transfer to oversteer. This allows the front wheels to stay on the ground for cornering, & helps the back wheels to get traction by transferring weight onto them.
Front wheel drives need bigger bars on the rear to stop weight transfer onto them as you need weight to stay on the driving wheels.
Either way, get the front bar first. It might look big, but the stiffness depends on the steel used & whether the bar is hollow or solid.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: Swaybars? Wed, 25 September 2002 01:54 Go to previous messageGo to next message
GIN51E wrote on Wed, 25 September 2002 08:45
Other way around dude. Smile
Front induces understeer, and vice versa.
As Steve said, get the front done first. You don't want to drive a RWD with a soft front and hard rear....
GIN51E
Berowra-Sydney
Re: Swaybars? Wed, 25 September 2002 01:58 Go to previous messageGo to next message
Laughing i said i'd probably be wrong Razz
Sonic
Re: Swaybars? Wed, 25 September 2002 03:58 Go to previous messageGo to next message
So where do you get swaybars from?
I am interested in trying them out on my '98 Celica SX.
Any recommendations would be appreciated!
Nark
Cabramatta, NSW
Re: Swaybars? Wed, 25 September 2002 04:26 Go to previous messageGo to next message
Whiteline and K-Mac are two Australian companies that do them...
I have K-Macs on mine. They're pretty stiff though, not everyone's cup of tea...
For a FWD, you'd usually want to put a bigger rear one in first. Gives it better turn in response and a more "taily" attitude mid-corner.
[Updated on: Wed, 25 September 2002 04:29]
Sonic
Re: Swaybars? Wed, 25 September 2002 05:01 Go to previous messageGo to next message
Thanks very much I will look into that.
Where did you purchase yours?
Steve.
Re: Swaybars? Wed, 25 September 2002 09:04 Go to previous messageGo to next message
Get both while you're at it. They're not that pricey, and they do a good job, something every car should have Very Happy
wilbo666
Re: Swaybars? Wed, 25 September 2002 11:21 Go to previous messageGo to next message
Yeah prices from white line were heaps better than I expected.
Front $199
Rear $160
Not bad really!
Will they really transform the car tho?
JAZE
cronulla
Re: Swaybars? Wed, 25 September 2002 11:59 Go to previous messageGo to next message
ive heard that fitting a front and a rear swaybar can screw your handling up, does anyone else know anything about that?
Soarer
Wollongong
Re: Swaybars? Wed, 25 September 2002 14:38 Go to previous messageGo to next message
Fitting front & rear sway bars was the single best improvement I did to my '96 Vienta (previous car). Absolutely changed the car's handling (which was far from perfect in stock form).
Installed a 26mm front bar and a 22mm rear bar for a ridiculous improvement in handling and turning response. Cost $550... every cent worth it in my opinion.
I want to replace the ones on my Soarer one day (silly hollow tubes) with solid bars, but am a little more wary, as I have twice the power and only 200kg more than the previous car. Not a fan of uncontrollable sideways action, but I do know that I definitely need to change the front one first.
Nark
Cabramatta, NSW
Re: Swaybars? Thu, 26 September 2002 00:06 Go to previous messageGo to next message
I bought mine direct from K-Mac.
Swaybars will give you an incredible improvement in controlling body roll.
Re: Swaybars? Thu, 26 September 2002 00:17 Go to previous messageGo to next message
So the K-Mac bars are the best? More solid?
What about ajustable panhard rods? These are hollow right? Would this be a weak point in the drivline? I mean would a hollow bar be suitable for a panhard rod?
wilbo666
Re: Swaybars? Thu, 26 September 2002 00:42 Go to previous messageGo to next message
If you lower the car you need an adjustable panhard rod don't you? Do you have to buy one or can you just cut the old one and weld in threaded pieces to make it adjustable?(too weak?).
Re: Swaybars? Thu, 26 September 2002 01:19 Go to previous messageGo to next message
Well thats what i'm wondering! But if all the ajustable rods are hollow i'm thinking that there must not be much load on the rod?
Thinking about it, it does'nt really do to much Rolling Eyes
Re: Swaybars? Thu, 26 September 2002 01:30 Go to previous messageGo to next message
The basic idea is, if you lower your car, but don't fit one, you'll have your diff hanging off to one side...
wilbo666
Re: Swaybars? Thu, 26 September 2002 01:57 Go to previous messageGo to next message
Yeah I get what the effect of lowering is on the diff via the panhard rod, what I am interested in is the possibility of making an adjustable panhard rod out of the original!
Or should you just buy one?
How much are they? Probably not that much, just curious is all!
Re: Swaybars? Thu, 26 September 2002 02:27 Go to previous messageGo to next message
They are $109 from whiteline!
What I want to know is what kind of stress is on one of these?
Is a hollow item ok for just a street car and do I need a solid for a race car? What do I need?
GIN51E
Berowra-Sydney
Re: Swaybars? Thu, 26 September 2002 03:11 Go to previous messageGo to next message
stress? well lets put it this way, mine is being held on by a few cable ties with no problem does that answer your question?
Re: Swaybars? Thu, 26 September 2002 03:19 Go to previous messageGo to next message
Sort of.. I'm just worried about the rod flexing and then snapping Shocked This could be painful Confused
GIN51E
Berowra-Sydney
Re: Swaybars? Thu, 26 September 2002 03:44 Go to previous messageGo to next message
Pan hard bar stops diff from moving side to side, doesn't take a huge amount of strength to hold it as you also have all the trailing arms and so forth.
it would only be a big issue on a very heavy car.
the only time i've ever heard of a pan hard bar braking and thats from some sort of impact such as a gutter and so forth.
your main issue with cutting it and putting in a threaded link would be corrosion of the two different metal types and thats what would caue it to most likely break
GIN51E
Berowra-Sydney
Re: Swaybars? Thu, 26 September 2002 03:46 Go to previous messageGo to next message
and a for hollow ones, well depends on how hollow it is, often some sway bars are hollow and think of the kind of stress they have to handle where they are always trying to flex but have you heard of one snapping?
Re: Swaybars? Thu, 26 September 2002 03:56 Go to previous messageGo to next message
Just remember that the panhard rod does stop the diff from spitting out the side of the car! Now imagine the load on it when screaming around a corner Shocked This is exactly what i'm worried about Confused
troyboy
Colyton, NSW
Re: Swaybars? Thu, 26 September 2002 04:24 Go to previous messageGo to next message
okok
i have fwd
i have ae93 seca
what size rear swaybar should i get??
should it be adjustable?
would i really adjust it?
i dont plan to go on the track.. and if i did .. it would be only once...
GIN51E
Berowra-Sydney
Re: Swaybars? Thu, 26 September 2002 05:43 Go to previous messageGo to next message
i drove home without a pan hard bar and sure it moved around a fair bit but you would be surprised at how well the trailing arms keep it held in straight, as well as shocks and so forth all hold it in.
if you want to see how much work it actually does disconnect it and go for a drive around the block and you will see its not a big strength part of the car just a stabliser.
as for Troyboy, adjustable would only be good for track and if you actually know how to adjust it,
but could you ever be bothered climbing under the car and always frigging around with the adjustments to work out the best ride?
manipulate
Re: Swaybars? Thu, 26 September 2002 06:23 Go to previous messageGo to next message
So am i right in saying that if your gonna lower your car u should get swaybars AFTER u lower your car ???
Ta
Mani
Nark
Cabramatta, NSW
Re: Swaybars? Thu, 26 September 2002 06:28 Go to previous messageGo to next message
Troy, you should talk to Dave (dnation). He knows quite a bit about suspension mods on AE92s.
manipulate. You don't really need to upgrade the swaybars... Swaybars also provide similar improvements that stiffer springs proviede... The are pros and cons about each and getting the right ratio between swaybar and spring is a black art...
GIN51E
Berowra-Sydney
Re: Swaybars? Thu, 26 September 2002 08:21 Go to previous messageGo to next message
take V8 supercars for example, they have to keep adjusting there sway bars through the whole race depending on fuel load and tyre condition,
but suspension is to hard to fully understand anything and you should really find a place that really knows what there talking about and ask them what they think should be done to the car, let them have a drive off it so they see how it feels.
Blown86
Re: Swaybars? Thu, 26 September 2002 09:20 Go to previous messageGo to next message
Cool1 wrote on Thu, 26 September 2002 10:27
All depends on the wall thickness, diameter and steel alloy used.
A higher grade steel hollow bar will be stiffer than an inferior solid bar.
A hollow bar with a larger diameter will be stiffer than a solid bar with a smaller diameter using the same material.
Most race cars with a good suspension will use the appropriate type of hollow bars. Hollow bars are lighter.
Generally solid bars are used because they are cheaper.
The centre of a solid bar does not provide any strength in bending.
A properly designed bar will only bend at the maximum load required to transfer the appropriate weight to the unloaded (inside wheel) when cornering.
[Updated on: Thu, 26 September 2002 09:28]
Blown86
Re: Swaybars? Thu, 26 September 2002 09:26 Go to previous message
Cool1 wrote on Thu, 26 September 2002 11:56
A panhard rod is designed to keep the diff centred in the car for a given range of suspension movement.
This means it MUST stop the diff from 'spitting' out the side of the car.
Previous Topic:where to buy race gloves
Next Topic:4agze engine number? and side skirt for mr2 aw11? HELP ME!!
Current Time: Tue Nov 3 10:49:34 UTC 2026
Total time taken to generate the page: 0.19017195701599 seconds
