Toymods » Tech & Conversions » MX83 Rotors - HELP
DigitalAE86
MX83 Rotors - HELP Wed, 22 September 2004 11:38 Go to next message
I have a set of USA spec MX83 front brake rotors that I was planning to put on an '89 Cressida.
They have the following dimensions:
Centre Hole - 60mm
Height - 68mm
Thickness - 22mm
Diameter - 279mm
They are the same as an Aussie series 2 MX83 rotors, except for the diameter, which is 23mm larger.
I also have a set of pads (Nippon brand) that came with the rotors and they're exactly the same as the Aussie ones.
How can I make these rotors fit? (Note that I have Aussie series 2 calipers).
Any advice would be greatly appreciated.
[Updated on: Thu, 23 September 2004 06:36]
Re: MX83 Rotors - HELP Wed, 22 September 2004 23:03 Go to previous messageGo to next message
Well the rotors will obviously fit, but you're going to have clearance problems with the calipers. You'll have to either relocate them somehow or use different ones (eg US-spec MX83 calipers).
DigitalAE86
Re: MX83 Rotors - HELP Fri, 24 September 2004 13:12 Go to previous messageGo to next message
If I can't find a solution they'll be up for sale. Although I'd really prefer to have them on my car.
mx83toy
Re: MX83 Rotors - HELP Sun, 26 September 2004 04:43 Go to previous messageGo to next message
i have JZX81 Chaser ones in my MX83 try and getyourself complete stuts and change the lot staight ova
DigitalAE86
Re: MX83 Rotors - HELP Wed, 29 September 2004 03:51 Go to previous messageGo to next message
I'm open to all reasonable suggestions!!!
mx83toy
Would you know if the JZX81 Chaser set up is the same as the US Cressida? What's the diameter of your discs?
[Updated on: Wed, 29 September 2004 03:53]
ra23celica
Re: MX83 Rotors - HELP Wed, 29 September 2004 06:04 Go to previous messageGo to next message
Rather than going to all the trouble of hunting down and then fitting Chaser front struts, get a bracket engineered to fit between your calipers and the original caliper mounting brackets.
DigitalAE86
Re: MX83 Rotors - HELP Wed, 29 September 2004 11:49 Go to previous message
That suits me fine, what sort of business should I be looking for to get the job done?
Does anyone in Melbourne know somewhere that they can recommend?
Previous Topic:quick soarer qs
Next Topic:Soarer SC400 92 V8 - Need Workshop Manual
Current Time: Tue Oct 20 01:38:22 UTC 2026
Total time taken to generate the page: 0.10708093643188 seconds
