Toymods » Tech & Conversions » 4A GZE Injector Plugs
takai
4A GZE Injector Plugs Wed, 22 September 2004 12:03 Go to next message
Does anyone know where i can get some gze injector plugs from. Just the plugs with clips.
I only just noticed that the 100kw plugs are slightly different from the GZE plugs.
ae86drift
sydney.au
Re: 4A GZE Injector Plugs Wed, 22 September 2004 12:25 Go to previous messageGo to next message
ask mr kellam! hes the toyota loom king!
ae86trueno
Re: 4A GZE Injector Plugs Thu, 23 September 2004 00:59 Go to previous messageGo to next message
hmmm
Tip for the day
high Ohm injectors go into High ohm plugs
Low Ohm injectors use low ohm plugs
I have a set if you get stuck..
Ben.
takai
Re: 4A GZE Injector Plugs Thu, 23 September 2004 02:01 Go to previous messageGo to next message
Yes, but the high ohm GZE injectors are reversed (locking nub on opposite side) to the 100kw high om injectors.
ae86trueno
Re: 4A GZE Injector Plugs Thu, 23 September 2004 02:23 Go to previous messageGo to next message
Ahh is far is i knew there was only 1 type of GZE injector
the redish orange one that is 2.9 Ohm !??
ben.
takai
Re: 4A GZE Injector Plugs Thu, 23 September 2004 02:34 Go to previous messageGo to next message
Yup, red orange, but it uses a different plug to the high ohm GE 100kw ones.
So the high/low ohm difference doesnt matter, the GZE plugs are different again from the GE ones.
ae86trueno
Re: 4A GZE Injector Plugs Thu, 23 September 2004 02:47 Go to previous messageGo to next message
Yes thats right
the GZE has a different plug to the 100KW High Ohm because its a Low Ohm injector.
low omh plugs look like this
http://www.geocities.com/MotorCity/Pit/9975/enginepix/drawings/conn1e.gif
High ohm plugs look like this
http://www.geocities.com/MotorCity/Pit/9975/enginepix/drawings/conn3f.gif
Ben.
takai
Re: 4A GZE Injector Plugs Thu, 23 September 2004 06:25 Go to previous messageGo to next message
Ah i thought the low ohm injector plugs were the square ones.
Now where do i get some from?
EDIT: Phoned Toyota and the part listing doesnt come up on the stock list.
[Updated on: Thu, 23 September 2004 22:05]
parrot
Re: 4A GZE Injector Plugs Fri, 24 September 2004 01:07 Go to previous messageGo to next message
Quite seriously, have a wander around pick a part and check out the jap fuel injected cars. Bound to find what you want easily and dare I say it - free!
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: 4A GZE Injector Plugs Fri, 24 September 2004 02:35 Go to previous messageGo to next message
Ahh the rounded type injector plug. I had trouble finding these plugs, still havent Razz
They are made by nippon denso i believe which make the plugs a bit more unique in comparison to the squarer bosch style ones.
Good luck.
parrot
Re: 4A GZE Injector Plugs Sat, 25 September 2004 14:46 Go to previous messageGo to next message
You can find type E connectors on 3S-FE camry's, 4AGE red top 86kw, 7M-GTE amongst others. There are about 5 3SFE Camry's at Kilsyth right now.
takai
Re: 4A GZE Injector Plugs Sat, 25 September 2004 22:07 Go to previous messageGo to next message
Currently im in Canberra, but ill have a look around. Also the bigport 4A injectors arnt E type, they are the square type.
That said the only difference in plugs between the E type and the F type is the location of the notch. Sidecutters can easily butcher the plastic and cut a recess so they fit Very Happy
Good enough till i get proper ones.
parrot
Re: 4A GZE Injector Plugs Sun, 26 September 2004 12:51 Go to previous messageGo to next message
You will find the late 86kw front drive motor with pink injectors have the E type connector.
Re: 4A GZE Injector Plugs Sun, 26 September 2004 13:55 Go to previous messageGo to next message
I may have a set amongst a box of wiring bits I've got, and I live about 2 mins drive from Pinch-a-Part Kilsyth
parrot
Re: 4A GZE Injector Plugs Sun, 26 September 2004 14:22 Go to previous messageGo to next message
Get the Camry ones, they are everywhere. The pink injector 4AGE ones I have came with a motor i bought yonks ago.
takai
Re: 4A GZE Injector Plugs Sun, 26 September 2004 21:35 Go to previous messageGo to next message
Aye, this would not be a problem if i was in Melbourne. Pity Canberra has no real Pickapart.
10sec_rx7
Syndey
Re: 4A GZE Injector Plugs Sun, 26 September 2004 23:34 Go to previous messageGo to next message
you can grind the locating lug off the injector and it will plug in no problems at all,
i can also supply new high or low key way plugs for these injectors
Dale
takai
Re: 4A GZE Injector Plugs Sun, 26 September 2004 23:44 Go to previous messageGo to next message
Well it doesnt really matter now. My ECU was stolen overnight, so i need a new one anyway, which means rewiring.
How much do you want for a set of E type plugs Dale?
10sec_rx7
Syndey
Re: 4A GZE Injector Plugs Mon, 27 September 2004 00:01 Go to previous messageGo to next message
a set of Low keyway denso's are $65 plus postage for 4 new unassembled plus ( you have to attach your wires to the pins and assemble the connector)
what ecu got flogged??
takai
Re: 4A GZE Injector Plugs Tue, 19 October 2004 09:26 Go to previous messageGo to next message
Thanks guys, i needed some in a hurry and was able to get them from my local spares place. Ill get the name of the cattledog which they were in tomorrow when i go pick them up.
takai
Re: 4A GZE Injector Plugs Sat, 04 June 2005 06:08 Go to previous messageGo to next message
I just had to buy more injector plugs, and i remembered this thread. The company who makes them is ACA. and the part number is TC131
Be careful where you buy them, i was quoted $42 each from one place. Ended up getitng all four for $26
Rallystanza
Re: 4A GZE Injector Plugs Sat, 04 June 2005 06:39 Go to previous messageGo to next message
Chris,
Perhaps a noob question, but does the injector, injector plug, injector wiring or ECU determine the impedence of injectors?
Jezza
sideshow
Re: 4A GZE Injector Plugs Sat, 04 June 2005 07:49 Go to previous messageGo to next message
if the engine has a dropping resitor then the injectors are low ohms or impedance
takai
Re: 4A GZE Injector Plugs Sat, 04 June 2005 10:52 Go to previous message
Injectors are either high or low impedence. And its up to the ECU to be able to work with it. Low impedence can use a resistor pack to be converted.
Previous Topic:Holden Nova
Next Topic:upgrade from ct20
Current Time: Thu Oct 22 06:54:26 UTC 2026
Total time taken to generate the page: 0.0073928833007812 seconds
