Toymods » Tech & Conversions » 5M-GE - Replace 2LT
mtx1
5M-GE - Replace 2LT Wed, 22 September 2004 22:21 Go to next message
Hi All,
I am thinking of putting a 5MGE in my hilux surf IFS to replace a 2LT. Does this swap ok. Has anyone done it?
I heard there might be an issue on an IFS with the 5M-GE Sump.
Any feedback will be appreciated.
Supralux
Re: 5M-GE - Replace 2LT Thu, 23 September 2004 03:09 Go to previous messageGo to next message
do a search on here: http://www.outerlimits4x4.com/PHP_Modules/phpBB2/
I have a solid axle 84 lux with a 5mge. it should be running within the next week if i pull my finger out.
I think the engine mounts with the 2lt line up very closely to the 5mge ones. you can also have a look here: http://www.4wd.net.nz/suprasurf.htm
and here: http://www.4x4wire.com/toyota/tech/supra/swap1p3.h tm
you can get diferent sumps to fit around the ifs im quite sure.
Re: 5M-GE - Replace 2LT Thu, 23 September 2004 03:56 Go to previous messageGo to next message
How old is your Hilux? If it's newer than 1986, a 5M conversion won't be legal. Sad
Re: 5M-GE - Replace 2LT Thu, 23 September 2004 04:04 Go to previous messageGo to next message
Unless that 5MGE is from a Cressida.
mtx1
Re: 5M-GE - Replace 2LT Thu, 23 September 2004 04:16 Go to previous messageGo to next message
It is a 1990
Re: 5M-GE - Replace 2LT Thu, 23 September 2004 04:19 Go to previous messageGo to next message
Out of luck then dude, the 5MGE is too old.
ed_ma61
Lost in the K hole
Re: 5M-GE - Replace 2LT Thu, 23 September 2004 06:44 Go to previous messageGo to next message
solution: 7mge
Re: 5M-GE - Replace 2LT Thu, 23 September 2004 06:50 Go to previous messageGo to next message
Better solution: 2JZ-GE. Razz
Re: 5M-GE - Replace 2LT Thu, 23 September 2004 06:51 Go to previous messageGo to next message
Best solution: 1UZ-FE Laughing
ed_ma61
Lost in the K hole
Re: 5M-GE - Replace 2LT Thu, 23 September 2004 06:55 Go to previous messageGo to next message
7mge, the longer stroke would perhaps work better for a 4wd...
it isnt called a tractor engine for nothing Razz
Re: 5M-GE - Replace 2LT Thu, 23 September 2004 06:56 Go to previous messageGo to next message
Stroke isn't going to make up for a litre of missing displacement.
mtx1
Re: 5M-GE - Replace 2LT Fri, 24 September 2004 02:02 Go to previous messageGo to next message
I have heard there are space issues with the 1uz-fe
although gotta love the sound of a V8.
The sump is apparently an issue with the IFS on these and also trying to keep them cool is very hard in the surf.
I am not sure of this, just what I have been told.
Re: 5M-GE - Replace 2LT Fri, 24 September 2004 02:09 Go to previous messageGo to next message
1UZFE is fairly wide yes, but you could be a pioneer! Get out your tape measure and see if it'd fit. There are a few different sump setups available and surely one of them, or a slightly modified one of them would have to fit.
Evil_Foetus
Ballarat, Victoria
Re: 5M-GE - Replace 2LT Fri, 24 September 2004 02:14 Go to previous messageGo to next message
i think its only some states that enforce the "engine must not be older than car" rule...
i think, anyone clarify this?
Re: 5M-GE - Replace 2LT Fri, 24 September 2004 02:17 Go to previous message
Yeah, WA is very slack in this regard Smile
Previous Topic:Bushings for ae86
Next Topic:TEMS help needed ASAP
Current Time: Sun Nov 1 05:03:01 UTC 2026
Total time taken to generate the page: 0.0051901340484619 seconds
