Toymods » Tech & Conversions » Brackets for fuel tubing?
Brackets for fuel tubing? Thu, 23 September 2004 05:26 Go to next message
Hey all,
anyone have suggestions for donor cars to source fuel pipe brackets? to run two 5/16 tubes front to back in car otherwise unequipped. or aftermarket sources?
for new install of EFI into poor old car Wink
shinybluesteel
melbourne
Re: Brackets for fuel tubing? Thu, 23 September 2004 05:31 Go to previous messageGo to next message
aftermarket, i know you can get them from earl's, but what i would do is get some aluminium flat section, some steel rod the same diameter of the tubing and hammer (so it ends up in a "P" cross section) the aluminium around it then drill holes through for bolts.
or use zip ties Rolling Eyes
Re: Brackets for fuel tubing? Thu, 23 September 2004 05:39 Go to previous messageGo to next message
mmm zip ties?? no... Wink
had that thought, but i want a compact mounting for two tubes, with plastic/rubber to prevent chafing... must satisfy engineer Wink
hmmmm, maybe .. drill hole in middle, and bend each end around a 15mm metal former, so the ends meet up in the middle and have hole in them....then slit a length of fuel tube to be the 'cushion'
still sounds harder to make them look neat... than unbolting off another car Wink
but i'll give it a go.
ke382TG
Re: Brackets for fuel tubing? Thu, 23 September 2004 06:22 Go to previous messageGo to next message
Stewart,
The company called "Wurth" (German parts and tool company etc) makes something that sounds like exactly what you are after.
The "P" shaped bracket is steel with rubber on the part that would be in contact with the hose. They come in more sizes than you can poke a stick at and cost very little. They look uber neat and weight SFA.
I only know they exist because we used to use and buy heaps of them when I worked in a bike shop.
They sound like they would do the job you want.
Anyone who deals with Wurth (most car parts places) could get you a box of 25 of them. Better than zip-ties!
Re: Brackets for fuel tubing? Thu, 23 September 2004 07:30 Go to previous messageGo to next message
http://www.inlinetube.com/images/brake%20&%20fuel%20Clips/clips%20small%20(7).JPG
top right is something i was trying to describe Wink
hmm, like these ones?
http://www.amstreetrod.com/Accessories/f171003ERL.jpg
these are nice, but overkill..non-cushioned and single pipe only
http://www.amstreetrod.com/Accessories/f170008ERL.jpg
these are also interesting
http://www.made4uproducts.com/images/Oil%20Lines%20Gray%20xs.jpg
but a donor car could be easier Wink
bmak
Re: Brackets for fuel tubing? Thu, 23 September 2004 11:40 Go to previous message
got to an LPG installer.
They will have heaps of diffrent types, thats how i got them
about 50cent each
Previous Topic:JZA70 R154 gearbox questions
Next Topic:Spegit shaft bearing replacement
Current Time: Sat Oct 31 03:09:53 UTC 2026
Total time taken to generate the page: 0.0040469169616699 seconds
