Classifieds » Miscellaneous » FS mazda rx7 series 6 4piston calipers
68rolla
FS mazda rx7 series 6 4piston calipers Thu, 23 September 2004 06:27 Go to next message
I was told series 4/5 and series 6 were the same, they doo look very similar- but slightly different (bigger) Pads look near new.
Phils rotary charges $450 a pair.
Chasing $250.
In brisbane- can post at buyers expence.
Grant
0402 738 017
GrantG@Bigpond.net.au
steve-O
wollongong
Re: FS mazda rx7 series 6 4piston calipers Thu, 23 September 2004 06:54 Go to previous messageGo to next message
if they are the same as series 4 and 5 then i mite be interested
Re: FS mazda rx7 series 6 4piston calipers Thu, 23 September 2004 11:28 Go to previous messageGo to next message
68rolla wrote on Thu, 23 September 2004 16:27
Re: FS mazda rx7 series 6 4piston calipers Thu, 23 September 2004 11:31 Go to previous messageGo to next message
Whats different about them?
V8_MA61
Re: FS mazda rx7 series 6 4piston calipers Thu, 23 September 2004 13:43 Go to previous messageGo to next message
i think they are bigger also...mine arte series 6..
Godzilladat
The winner is Sydney
Re: FS mazda rx7 series 6 4piston calipers Thu, 23 September 2004 16:26 Go to previous messageGo to next message
$250 is the going price for these on internet forums. I couldnt find a set for less than $375 from any importer.
I just picked up a set for the same price with pads, good luck with the sale, if you have any problems just throw them on www.ausrotary.com and they will go like hotcakes.
Re: FS mazda rx7 series 6 4piston calipers Fri, 24 September 2004 01:27 Go to previous messageGo to next message
Bigger in what way? Pistons are the same size according to rebuild kit part numbers. Are the bolt spacings different?
Maybe I should come and grab that one you have Blake and check it out for my self.
V8_MA61
Re: FS mazda rx7 series 6 4piston calipers Fri, 24 September 2004 13:57 Go to previous messageGo to next message
come round tommorow nite if you want shane, SMS me first.
68rolla
Sold series 6- Buying series 4/5 Sat, 25 September 2004 01:45 Go to previous messageGo to next message
They look identicle so i guess the piston size would be the same- the only reason i said bigger was from the dba web site lists the rotors as larger- my mistake.
Calipers have been sold- I am still looking for series 4/5 if any1 has a spare set.
Grant
Henn
Rosanna, Melb
Re: FS mazda rx7 series 6 4piston calipers Sat, 25 September 2004 06:47 Go to previous messageGo to next message
I have a rotary-nut friend and from what I know, S6 have a 2mm thicker disc than S4/5 and it is slightly larger diameter too. So the calipers will be bloody similar, jsut with a fatter slot in them. May be slightly different mounts too.
Check to DBA catalogue to be sure on this though.
Hen
SSS610
Newcastle NSW
October 2005
Re: FS mazda rx7 series 6 4piston calipers Wed, 12 October 2005 16:21 Go to previous messageGo to next message
these still for sale?
170bhp
Re: FS mazda rx7 series 6 4piston calipers Mon, 17 October 2005 00:56 Go to previous message
the difference between series 4/5 and 6 is the casting technique, series 6 are squeeze cast, slightly lighter and stiffer than previous (not that series 4/5 have a problem with flex), all series 4/5/6 have the same size pistons. Series 7 are squeeze cast but have different sized pistons trailing and leading to stop pad taper wear(I use these). Series 8 also use different sized pistons but are designed to take a rotor which is 32mm thick(like and SP, which basically just used RZ JDM calipers). Note that some series 7 also have the larger calipers(designed for thicker disc) but not on Aus models, all Aus modes series 4/5/6/7 are designed to be used with 22mm thick disc.
Previous Topic:Nokia 3200 For sale
Next Topic:JZA80 Supra and Soarer parts new and used for sale
Current Time: Fri Oct 23 23:31:46 UTC 2026
Total time taken to generate the page: 0.0055088996887207 seconds
