Toymods » Tech & Conversions » Anyone have experience with 1jz in s13 conversion?
1j180
A.C.T.
Anyone have experience with 1jz in s13 conversion? Thu, 23 September 2004 13:00 Go to next message
Hoping to discover likley issues before they are encountered. I'm aware of engine mount issues, they are already solved. Also aware the gearbox crossmember will require modification. Haltech E6k comp is being used so no major wiring headaches. Any insights or advice would be great thanks.
Re: Anyone have experience with 1jz in s13 conversion? Thu, 23 September 2004 13:34 Go to previous messageGo to next message
What gearbox you got in mind?
1j180
A.C.T.
Re: Anyone have experience with 1jz in s13 conversion? Thu, 23 September 2004 13:46 Go to previous messageGo to next message
I was thinking the w58 but I'm open to suggestions???
Re: Anyone have experience with 1jz in s13 conversion? Fri, 24 September 2004 00:29 Go to previous messageGo to next message
A W58 is probably ok in an S13, they're pretty light cars (similar to an MA61 I imagine, and plenty of 1JZ MA61's are using W58 gearboxes).
So you have the engine and gearbox mounting issues sorted, and the wiring is being handled by the Haltech, so it sounds like you're most of the way there... I can't foresee any other issues apart from normal engine conversion stuff.
1j180
A.C.T.
Re: Anyone have experience with 1jz in s13 conversion? Fri, 24 September 2004 00:34 Go to previous messageGo to next message
Great, well I'm sure there will be some headaches but I guess no conversion espeically one of this nature is easy Smile
Thanks for the advice
Re: Anyone have experience with 1jz in s13 conversion? Fri, 24 September 2004 00:37 Go to previous message
Just check around and see which W58 shifter you'll need to use, from memory most Nissans have their gearstick fairly far bar, so you might need one of the rearmost shifter positiions available.
Previous Topic:TEMS help needed ASAP
Next Topic:mz21 soarer - looking to work/clean up
Current Time: Fri Oct 30 17:48:43 UTC 2026
Total time taken to generate the page: 0.0046429634094238 seconds
